johnhora |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None ![]() ![]() |
Looking for a source for Bosch OEM electric fuel pump rebuilding and testing.
Thanks |
dakotaewing |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,163 Joined: 8-July 03 From: DeSoto, Tx Member No.: 897 Region Association: Southwest Region ![]() ![]() |
I'd be interested in this as well as I know I have at least one, and possibly more.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,339 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
New Bosch 2 port at Napa is around$100
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,188 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,778 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
Looking for a source for Bosch OEM electric fuel pump rebuilding and testing. Thanks For Fuel injection or carbs ? Either way, contact Peter at pgeorge911@aol.com He recently did the 009 Bosch fuel pump for my carbed 6, tested with printed results. Great results. |
johnhora |
George and rgalla9146...Thanks!! exactly the info I was looking for...
TheCabinetmaker thanks...it's an 009 |
73-914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 618 Joined: 24-April 10 From: Albany UpstateNY Member No.: 11,651 Region Association: None ![]() ![]() |
rgalla9146 |
George and rgalla9146...Thanks!! exactly the info I was looking for... TheCabinetmaker thanks...it's an 009 If your car is a real 6 with stock fuel plumbing (return circuit) go with the 009 If your car is a conversion (supply only) get a Carter rotary pump. It is a modern pump designed for carbs, no regulator needed, 2.5 to 3.5 psi. About $90. on Amazon. Be careful not to get the similar Diesel version that costs less. Trouble finding it ? get back to me. A $20 pump makes a racket. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,257 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
If you are running carbs in 2020 you are an idiot and it's ok to you use a a low pressure pump. LOL Sounds like somebody need to take a couple of ludesCleanup on isle 914 ... (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/FERG.gif) |
SteveL |
Senior Member ![]() ![]() ![]() Group: Members Posts: 663 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None ![]() ![]() |
If you are running carbs in 2020 you are an idiot and it's ok to you use a a low pressure pump. LOL Sounds like somebody need to take a couple of ludesCleanup on isle 914 ... (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/FERG.gif) Thank You Sir. |
porschetub |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,883 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None ![]() |
If you are running carbs in 2020 you are an idiot and it's ok to you use a a low pressure pump. LOL Sounds like somebody need to take a couple of ludesCleanup on isle 914 ... (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/FERG.gif) Well done ,about time ,some times entertaining but generally rude and non constructive to this forum. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
johnhora |
Thanks for the Clean Up...appreciated
Jonathan Livesay |
Senior Member ![]() ![]() ![]() Group: Members Posts: 745 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None ![]() ![]() |
If you are running carbs in 2020 you are an idiot and it's ok to you use a a low pressure pump. LOL Sounds like somebody need to take a couple of ludesCleanup on isle 914 ... (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/FERG.gif) Talk about a mean drunk. (IMG:style_emoticons/default/dry.gif) |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If you are running carbs in 2020 you are an idiot and it's ok to you use a a low pressure pump. LOL Sounds like somebody need to take a couple of ludes Nice reference to a drug not available in this century. Making me feel old. (IMG:style_emoticons/default/agree.gif) Everything I want to say here just makes me look (IMG:style_emoticons/default/slits.gif) |
Lo-Fi Version | Time is now: 13th July 2025 - 07:03 PM |
