High Idle, screw in the buterfly hole. |
CheeRS |
Apr 16 2020, 03:33 PM
Member Group: Members Posts: 93 Joined: 5-May 19 From: Paris France Member No.: 23,093 Region Association: France |
Bonsoir,
I bought in France a few monthes ago an import from US 2.0 GA. Great car, rust free, dolphin green but re painted but Ray Charles or Stevie in red. I started a big service of the car to fix all the small PB it has. First one is a very high idle. Throttle seems to be a very high mileage one, there are some spaces between the buterfly and the body. This is perhaps why the hole in the butterfly is closed by a screw in it. With the idle air screw fully closed, idle is at 1600, turning the screw operate on the idle, but could only make it higher. Tomorrow I will check ignition timing. It seems to me there is no air leak, the only one is across the buterfly play. Is it a common fail ? Should I re-put the screw in the hole ? Thanks CheeRS |
second wind |
Apr 16 2020, 07:06 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Sounds like a timing issue to me. Had the same problem and the mechanic had the timing off 180 degrees. Never went back there again.
gg |
TheCabinetmaker |
Apr 17 2020, 06:00 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Vacuum leak!
Mark Henry |
Apr 17 2020, 08:57 AM
Or very poorly adjusted linkage.
CheeRS |
Apr 21 2020, 02:47 PM
CheeRS |
Apr 21 2020, 02:57 PM
yellowporky |
Apr 21 2020, 03:21 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
CheeRS |
Apr 21 2020, 03:33 PM
whaou ;-) thank U
Rand |
Apr 21 2020, 03:39 PM
I wouldn't go to timing issue first. Well, I mean it needs to be accurate, but... Vacuum leak if FI. Hopefully no carbs, but you didn't say what your system is. I think Curt nailed it.
CheeRS |
Apr 22 2020, 03:19 PM
The system is a stock Djet GA engine.
No modification. Now run fine, start like a champion, cold idle at 1400 and 1000 after 2 minutes. |
StarBear |
Apr 22 2020, 03:41 PM
Senior Member Group: Members Posts: 1,914 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
(IMG:style_emoticons/default/piratenanner.gif) Yet another success story!
Lo-Fi Version | Time is now: 11th June 2024 - 08:15 AM |
