914 RZ-1 |
Porsche Padawan ![]() ![]() ![]() Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California ![]() |
I stripped the threads on one of my lug bolts. The part number is 914 361 315 01 or 02. They are $25 each on Pelican! They are also pretty pricey on Ebay and other Porsche suppliers.
My FLAPS says they can get a set of 10 for around $65. I searched around on this site and others and found a reference to this VW part number (thanks to @ClayPerrine ): 701 601 139B. I found these two sources: This site has other sizes. I'm not sure what the length in the description refers to; the OAL or the length of the threaded part. I need a minimum of 30 mm of thread. These are $1.74 each. I will contact them and see if they have any more details. The "fitment" says they don't fit a 914, but they look like the same bolt. I tried the fitment on several different sizes and they all "didn't fit". https://www.ecstuning.com/b-febi-parts/wheel-screw/701601139b~feb/ This site has the VW ones for $1.46 each. The "fitment" says they don't fit a 914, but they look like the same bolt. https://www.fcpeuro.com/products/vw-wheel-lug-bolt-eurovan-transporter-701601139b?ads_cmpid=1586103033&ads_adid=62588326769&ads_matchtype=&ads_network=g&ads_creative=298122218785&utm_term=&ads_targetid=pla-302307008361&utm_campaign=&utm_source=adwords&utm_medium=ppc&ttv=2&gclid=EAIaIQobChMI_8HFg5_u6AIV_z6tBh3KWg7jEAQYASABEgI28_D_BwE#description Does anyone have any experience using either of these on a 914? I have 4 lug Fuchs (probably repros, if that matters). |
914_7T3 |
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,853 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California ![]() ![]() |
@bdstone914 sells the correct 38mm length lug bolts replated.
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
I stripped the threads on one of my lug bolts. The part number is 914 361 315 01 or 02. They are $25 each on Pelican! They are also pretty pricey on Ebay and other Porsche suppliers. My FLAPS says they can get a set of 10 for around $65. I searched around on this site and others and found a reference to this VW part number (thanks to @ClayPerrine ): 701 601 139B. I found these two sources: This site has other sizes. I'm not sure what the length in the description refers to; the OAL or the length of the threaded part. I need a minimum of 30 mm of thread. These are $1.74 each. I will contact them and see if they have any more details. The "fitment" says they don't fit a 914, but they look like the same bolt. I tried the fitment on several different sizes and they all "didn't fit". https://www.ecstuning.com/b-febi-parts/wheel-screw/701601139b~feb/ This site has the VW ones for $1.46 each. The "fitment" says they don't fit a 914, but they look like the same bolt. https://www.fcpeuro.com/products/vw-wheel-lug-bolt-eurovan-transporter-701601139b?ads_cmpid=1586103033&ads_adid=62588326769&ads_matchtype=&ads_network=g&ads_creative=298122218785&utm_term=&ads_targetid=pla-302307008361&utm_campaign=&utm_source=adwords&utm_medium=ppc&ttv=2&gclid=EAIaIQobChMI_8HFg5_u6AIV_z6tBh3KWg7jEAQYASABEgI28_D_BwE#description Does anyone have any experience using either of these on a 914? I have 4 lug Fuchs (probably repros, if that matters). Post a pic of the fuchs...especialy the seat...repros may have a different seat than stock. Been down this road. |
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,909 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Here you go. They are 2mm longer than stock but not a problem. They have a 17mm head instead of 19mm. Click on picture to open it up. 20 bolts shipped for $21.98
Attached thumbnail(s) ![]() |
914 RZ-1 |
914Sixer |
Scan Ebay, they have the bolts in black. I have the chrome ones on my roller car with Fuchs.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,679 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
914 RZ-1 |
I found some black ones. 17mm heads. Not sure if I care about that one way or another. Seems like all the VW stuff is 17mm.
I'm chatting with someone at a vendor. seems the bolts will fit. Anyone got pictures of 17mm ones? |
914 RZ-1 |
Is the length an issue? In other words, can I get longer ones? Stock is 38mm, but I only need about 30mm. The stock ones stick out about 8mm into the hub. There's room for longer bolts. I just want to confirm longer is ok before I buy anything.
If you look at the image of the stripped bolt, you can see the stripped area is where the threads engage the hub.There is about 20mm of thread, then about 11mm of stripped thread, then about 8mm of thread. The 8mm part is what extend into the hub. |
914 RZ-1 |
PM sent. |
Lo-Fi Version | Time is now: 16th June 2024 - 09:43 AM |
