914-6 stock six fuel pressure |
xsurfer |
Apr 28 2020, 03:23 PM
Member Group: Members Posts: 279 Joined: 4-April 06 From: La Canada, CA Member No.: 5,818 |
Please post the stock fuel pressure for a 914-6. I can't find my factory
manual. Thanks Gene |
gereed75 |
Apr 28 2020, 03:32 PM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Not sure what the manual says but all of the Weber experts say 3.5 psi.
porschetub |
Apr 28 2020, 11:23 PM
Advanced Member Group: Members Posts: 4,706 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Not sure what the manual says but all of the Weber experts say 3.5 psi. Running just over 3.0 psi but with Zenith carbs,some run less with no issues,if your float level are set correctly it means less,got one of those fuel bowl tools from Pelican...real handy. Good luck. |
porschetub |
Apr 28 2020, 11:38 PM
Not sure what the manual says but all of the Weber experts say 3.5 psi. Running just over 3.0 psi but with Zenith carbs,some run less with no issues,if your float level are set correctly it means less,got one of those fuel bowl tools from Pelican...real handy. Good luck. This item ; |
johnhora |
Apr 29 2020, 07:44 AM
Senior Member Group: Members Posts: 867 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Same specs as the 911T
ClayPerrine |
Apr 29 2020, 08:55 AM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
In the picture above, you need the pump for the 911T. Don't get the one for the 911 E or S. That is the feed pump for the MFI system. It is too high of pressure for carbs, and too low of pressure for EFI.
The factory Bosch pump for carbs looks just like the MFI and EFI versions. It just puts out a lot less pressure. Clay |
Lo-Fi Version | Time is now: 8th June 2024 - 05:07 PM |
