Help Needed - Air filter ports, Is there a special hose attachment ? |
frostyf |
May 3 2020, 09:29 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Hi, my 73 has the following type of air filter on a DJet 2.0L engine.
OD's : A is 13mm; B is 11mm; C is 13mm; and D is a whopping 20mm. The blanked off pipe between B and C is about 14mm. Is there a special elbow or spigot fitting that connects the hose to the large port (Marked D in the photo). Originally mine had a split water hose here. Looking at Jeff Bowlsby's diagram, its hose run 4 and includes an elbow marked 13 there and what appear to be two spigots - I've marked the connection I think goes between the hose and port D on the air filter with a light green circle in Jeff's diagram. I've bought some vacuum hose (12mm ID) and the elbow from the parts diagram (914 Vacuum Tube Elbow - New/Replacement R022129637). The hose runs from the Anti-Flash back valve I think to the air filter (that's my take from the diagram). Whilst the hose fits snug on the anti-flash back valve, the elbow or hose have absolutely no chance to stretch over the 20mm port on the air filter (marked D in the photo). Does anyone else have this air filter? I'm thinking there must be some kind of insert or adapter that fits into the large port on one side, then reduces to say 14mm for the vacuum hose on the other side. Can anyone shed any light on this or let me know if I've made a mistake interpreting the schematic? Is there a part number for a reducing connector that attaches the vacuum hose to the air filter? This diagram is marked for a 74 2.0L and perhaps I've got the incorrect air filter or diagram? The PET diagrams only seem to show the older round air filter box? I'd be v grateful if anyone can shed any light on this please; it might stop me going mad! Thanks - Nick Attached thumbnail(s) |
frostyf |
Feb 20 2021, 10:31 PM
Bump - still looking for some help with this please?
ejm |
Feb 21 2021, 06:07 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,694 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
You have the wrong air filter. The blocked off plate between B+C is for EGR which was used on some 75/76 cars. The anti-flash plumbing went away on the later cars and the 20mm fitting was for the crankcase breather.
frostyf |
Feb 21 2021, 09:41 AM
You have the wrong air filter. The blocked off plate between B+C is for EGR which was used on some 75/76 cars. The anti-flash plumbing went away on the later cars and the 20mm fitting was for the crankcase breather. Thanks Ed, does the crankcase breather have an adapter or connector or is it just a larger pipe diameter? |
ejm |
Feb 21 2021, 04:09 PM
Lo-Fi Version | Time is now: 9th June 2024 - 10:45 PM |
