> ET26 offset - what to expect?, 15" x 5.5" wheel
Literati914
post May 12 2020, 10:31 AM
thinking about some 15x5.5" wheels with an ET26 offset.. I know it'll kick the wheel out a bit over the stock ET40, but is it enough to be un-doable w/o spacers (which I'd like to avoid if possible)? I don't mind rolling the rear lip if necessary but I'm concerned about the fronts mostly.
Stick to a certain tire size?
I think some of the fuchs and cookie cutters that people use are ET23, right?
Replies(1 - 9)
Literati914
post May 12 2020, 02:52 PM
..anyone ?
Chris914n6
post May 12 2020, 03:39 PM
Jackstands are my life.
40-26=14mm -- so about 1/2" closer to the fender lip. You will be stuck with skinny tires.
et23 is on 7" wide wheels. So wider 1/2" outer and 1" inner.
914Sixer
post May 12 2020, 03:55 PM
Don't go that route. Use ET36 off set regardless of wheel type. Use a 6" wheel.
Literati914
post May 12 2020, 04:21 PM
Are we thinking the ET26 will have the fronts rubbing the outer lip or inner wall? ..because I thought there was an excess of outer wheel well in the front (when using stock wheels) ?
Literati914
post May 12 2020, 05:52 PM
In the Front: Is there room for a 1/2" wider lip on a stock sized wheel?
914Sixer
post May 12 2020, 09:12 PM
16 x 6 is a good choice all the way around.
Chris914n6
post May 12 2020, 11:55 PM
plenty of room in the front
Literati914
post May 12 2020, 11:57 PM
QUOTE(914Sixer @ May 12 2020, 10:12 PM) *
I appreciate that, but I've found a set of wheels that I reeaally like and that are dirt cheap.
I figure I can roll both front and rear lips if need be.. but I was wondering if that would be enough - or even necessary with ET26 on a 15x5.5 wheel. I was also hoping for at least 195x65r15 tires. A 185/70 may be better tho (IMG:style_emoticons/default/confused24.gif)
sixnotfour
post May 13 2020, 04:40 AM
- Lo-Fi Version Time is now: 1st May 2026 - 02:24 PM
