| dt4 |
May 17 2020, 12:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 503 Joined: 26-May 19 From: England Member No.: 23,161 Region Association: England
I have searched and browsed 914rubber but i am not finding the size or product I need to fix the grill to the engine lid, any pointers please?
| Craigers17 |
May 17 2020, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 880 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States
I have searched and browsed 914rubber but i am not finding the size or product I need to fix the grill to the engine lid, any pointers please? I'm in the process of refreshing the Deck lid and grill parts as well. I haven't gotten them fully sanded and painted yet, so I haven't reassembled. However, Mark at 914 Rubber told me that they don't include those push nuts in their Engine Deck Lid Kit because they have to get them from the Porsche dealer and they are pricey(if you call them, they CAN get them for you though). Since I'm not doing a Concours resto, I just went to the hardware store and bought these: I test fit these on the grill "prongs", and I think they are going to work fine. Good Luck! |
| dt4 |
May 17 2020, 01:18 PM
thanks, they look just the job, I will measure up the prongs and order similar on line
| bbrock |
May 17 2020, 02:00 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
They are still available through Porsche.
| Craigers17 |
May 17 2020, 03:26 PM
After doing a little more research going through the Porsche Parts catalog, I'm pretty sure this is the actual speed nut in question:
https://www.aasesales.com/products/h0c-b52-15i-104982 You can search on the part # and try to find different vendors with the best price. Doing a quick search, I found them here at $2.00/EA. For comparison, the push nut pictured in my first post above is around $ .42/EA at ACE Hardware. I think you need 18 of these to do the engine grill and both side grills. |
| 914Sixer |
May 17 2020, 05:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,433 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yep, that is the original one. Use the part number listed 999 507 220 40 and do on line search. Found them for $1.59 each at Gaudin Porsche.
| Ampex351 |
May 17 2020, 06:03 PM
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
I have searched and browsed 914rubber but i am not finding the size or product I need to fix the grill to the engine lid, any pointers please? 914 Rubber DOES have them. I just checked a while ago. I think theyre listed under "nuts and bolts". Or you can call them during the week. |
| mb911 |
May 17 2020, 07:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,723 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I bought some from 914rubber.. They are the push on speed nuts with Some sort of buytl under them I believe.
| dt4 |
May 18 2020, 03:42 AM
Thanks everyone, I will track some down
| dr914@autoatlanta.com |
May 18 2020, 09:05 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,232 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| 914_7T3 |
May 18 2020, 09:15 AM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
I bought some from 914rubber.. They are the push on speed nuts with Some sort of buytl under them I believe. Yes and different from the "Genuine" Porsche ones that are now hard plastic instead of the original ones that were much softer like rubber. Neither is ideal as the butyl ones get gooey in the heat and the plastic ones are real tough to snap on. (IMG:style_emoticons/default/sad.gif) |
| mb911 |
May 18 2020, 11:31 AM
I bought some from 914rubber.. They are the push on speed nuts with Some sort of buytl under them I believe. Yes and different from the "Genuine" Porsche ones that are now hard plastic instead of the original ones that were much softer like rubber. Neither is ideal as the butyl ones get gooey in the heat and the plastic ones are real tough to snap on. (IMG:style_emoticons/default/sad.gif) Agreed |
| dt4 |
May 19 2020, 06:44 AM
I picked these up for $3 for 25
They do the job perfectly although they are single use but for that price (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 14th March 2026 - 01:11 AM |
