Working on front suspension, Cleaning up and painting parts |
kroelofsen |
May 23 2020, 11:32 AM
Member Group: Members Posts: 100 Joined: 27-June 19 From: The Netherlands Member No.: 23,255 Region Association: Europe |
Today I cleaned and painted the parts of the front suspension. After blasting I put on primer first and when dry applied a nice coat of 2K paint.
Cairo94507 |
May 23 2020, 12:20 PM
Michael Group: Members Posts: 9,822 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Very nice- that's the way to do it. (IMG:style_emoticons/default/beerchug.gif)
barefoot |
May 23 2020, 03:20 PM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
While you're in there make sure to replace at least the rear A-arm bushings. They get flattened out over time and this causes the torsion bar inside to rub against the ID of the arm. this results in pitting corrosion and leads to a fatigue fracture of the bar, seen it several times. The forward bushing sees much less vertical load and doesn't get out of round.
Lo-Fi Version | Time is now: 7th June 2024 - 06:08 PM |
