/6 Rear Caliper Bleeder Location, What have I got here? |
zoomCat |
Jun 14 2020, 01:21 PM
Member Group: Members Posts: 162 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
I'm resurrecting /6 #2292 finally, and the brakes are going to get the full PMB treatment. The previous owner had put 911 front calipers on the back, but I picked up a couple used calipers years ago that were purported to be from a /6. They came with the spacer for vented disks, which was a real bonus. I bolted the passenger side up, and things look like they fit pretty well. Excuse the rust, all of this is going to cleaned up or replaced.
This looks like it should work, I think. But for the driver side has the bleeder on the bottom of the caliper, which I'm pretty sure is a problem. Are these Ferrari 308 calipers? Can the one caliper be drilled for a new bleeder? thanks, Guy |
Mark Henry |
Jun 14 2020, 01:27 PM
Get a piece of wood the thickness of the rotor, unbolt the caliper, jam the wood between the pads, flip the caliper upside down and bleed the caliper.
Bit of a PITA but it works. |
914Sixer |
Jun 14 2020, 02:03 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Seems as though you are correct, maybe 308 caliper.
Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 09:31 AM |
