Cylinder to head sealing ring |
76912E |
Jun 17 2020, 06:36 PM
Newbie Group: Members Posts: 26 Joined: 14-March 09 From: Freedom, NH Member No.: 10,163 Region Association: North East States |
I have a 1976 912E with the 2L Type 4 engine and L-Jetronic FI. I'm posting here because there are many more 914's than 912E's. The engine was rebuilt about 23 years ago with new, stock sized Euro pistons/cylinders, bearings and the heads rebuilt, etc. The car only has about 500 miles on it since the rebuild and has been stored inside all of that time. The last time I ran the engine, I noticed a rattling/banging noise in the area of the No. 1 & 2 cylinders (passenger side on a 912). Yesterday, I pulled the engine/transmission assembly to investigate further. My concern was a dropped valve seat. First, I adjusted all the valves with the intake manifolds off to observe intake valve action, by spinning the engine with the starter. I didn't hear any strange noises. The intake valves appeared seated. Next, I did a compression test and the No. 1 cylinder was at 50 PSI. The others were all above 100. I decided to pull the No.1-2 cylinder head to see if the exhaust valves were OK. I found that the cylinder to head sealing ring on the No. 1 cylinder had a one inch piece missing near the spark plug hole towards the exhaust valve. It looks as if the piston was beating on it a bit, hence the noise. Now for the problem. The head sealing surface has a small indent/scrap type scar (about an inch long) where the 2 ends of sealing ring broke away. I'm guessing the depth is a few thousands deep. Do you think if I "blend" the scar, by removing any high spots and just replace the sealing ring will work OK (it will completely cover the scar). Or, should I have the sealing area milled down on both cylinders? I live in the middle of the woods in Northern NH and don't have any local resources around that could do that type of work. The head would have to be sent out. Are there any good Type 4 head specialist in the New England area.
BTW, has anyone heard of a sealing ring doing this? They were all new at the time of the rebuild. Thanks, Fran |
bdstone914 |
Jun 17 2020, 07:24 PM
bdstone914 Group: Members Posts: 4,533 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@76912E
Yes I have seen head gaskets get sucked in. What i saw was a small section stay intact but pulled into the combustion area causing a major leak. VW issued a service bulletin to stop using them but Porsche did not on the same type IV engines. You may as well do a full head rebuild at thos point. That area needs to be fly cut to clean it up. If it is deep it should be welded up and then fly cut. |
porschetub |
Jun 17 2020, 08:28 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I have a 1976 912E with the 2L Type 4 engine and L-Jetronic FI. I'm posting here because there are many more 914's than 912E's. The engine was rebuilt about 23 years ago with new, stock sized Euro pistons/cylinders, bearings and the heads rebuilt, etc. The car only has about 500 miles on it since the rebuild and has been stored inside all of that time. The last time I ran the engine, I noticed a rattling/banging noise in the area of the No. 1 & 2 cylinders (passenger side on a 912). Yesterday, I pulled the engine/transmission assembly to investigate further. My concern was a dropped valve seat. First, I adjusted all the valves with the intake manifolds off to observe intake valve action, by spinning the engine with the starter. I didn't hear any strange noises. The intake valves appeared seated. Next, I did a compression test and the No. 1 cylinder was at 50 PSI. The others were all above 100. I decided to pull the No.1-2 cylinder head to see if the exhaust valves were OK. I found that the cylinder to head sealing ring on the No. 1 cylinder had a one inch piece missing near the spark plug hole towards the exhaust valve. It looks as if the piston was beating on it a bit, hence the noise. Now for the problem. The head sealing surface has a small indent/scrap type scar (about an inch long) where the 2 ends of sealing ring broke away. I'm guessing the depth is a few thousands deep. Do you think if I "blend" the scar, by removing any high spots and just replace the sealing ring will work OK (it will completely cover the scar). Or, should I have the sealing area milled down on both cylinders? I live in the middle of the woods in Northern NH and don't have any local resources around that could do that type of work. The head would have to be sent out. Are there any good Type 4 head specialist in the New England area. BTW, has anyone heard of a sealing ring doing this? They were all new at the time of the rebuild. Thanks, Fran Most likely is that one of the case sealing surfaces was pounded out or the barrels weren't checked for total height (less likely). The gasket needs to torque evenly on the heads to stay sealed and the above will cause an early failure which appears you have had. Failure of this gasket causes a rapid loss of exhaust gases which simply burn it out and generally damage the head to barrel sealing surface. Post some pics if you have them,cheers. |
Lo-Fi Version | Time is now: 4th June 2024 - 05:29 AM |
