WTB - V8 Radiator |
WTB - V8 Radiator |
DickSteinkamp |
Jun 18 2020, 07:59 AM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I have the Ron Davis/Renegade cooling system in my V8 914. The radiator started leaking and can't be repaired.
Any out there from stalled projects or parts stashes? Thanks. |
76-914 |
Jun 18 2020, 08:25 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I have the Ron Davis/Renegade cooling system in my V8 914. The radiator started leaking and can't be repaired. Any out there from stalled projects or parts stashes? Thanks. I have a couple that'll fit the 914 opening. One is single core one is dual core. I can pm you the make and general info on both if you'd like. Both with very limited use and one has the anode rod that targets the electrolysis. (IMG:style_emoticons/default/beerchug.gif) |
DickSteinkamp |
Jun 18 2020, 08:46 AM
I have a couple that'll fit the 914 opening. One is single core one is dual core. I can pm you the make and general info on both if you'd like. Both with very limited use and one has the anode rod that targets the electrolysis. (IMG:style_emoticons/default/beerchug.gif) PM sent. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:34 AM |
