push rod tubes, are they the same for stroker engines ? |
914rat |
Jun 18 2020, 10:40 AM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
I am building a 2257 engine and collecting the last bit of parts needed. Do I need to source special push rod tubes or will the stock 2.0 tubes work ?
Mark Henry |
Jun 18 2020, 12:42 PM
I have a 2.6 and had to make spacers for the case lifter bores. Head end pulled through too far with a lot of shim. I can't remember the exact size but it was over an .100 thick barrel shim.
Lo-Fi Version | Time is now: 6th June 2024 - 12:46 PM |
