| Speedo |
Jun 28 2020, 12:57 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 683 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains
Inner CV succumbed to the puller during removal. Need one please.
PM me with what you have. |
| 76-914 |
Jun 28 2020, 09:11 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Do you mean it separated and that the cage and bearings separated from the housing? If so that can be re-assembled. Describe or post a pic of the aftermath. (IMG:style_emoticons/default/beerchug.gif)
| abes914 |
Jun 29 2020, 02:22 AM
Member ![]() ![]() Group: Members Posts: 372 Joined: 30-March 11 From: Long Beach Member No.: 12,880 Region Association: Southern California
I had mine came apart when I drop my engine/transmission and found out I was missing a bearing. I got a bearing from a friend and was able to put it together. It was PITA but got easier after the 10th time (IMG:style_emoticons/default/dry.gif) There is a YouTube video that give instructions on how to properly out them together. I can forward the link if that is the issue you are having. |
| Speedo |
Jun 29 2020, 01:25 PM
I know how to disassemble and rebuild CVs. It did not come apart, it died. There are three primary pieces to the CV...outer flange, inner cage and carrier...plus six cool steel marbles.
The left side carrier is seized to the axle. Using a gear puller and heat we were trying to pull the entire CV off of the spline-d end of the axle. Cage was the weakest link and it broke. Probably could just replace the cage, but figured it would be easier to grab another used CV and rebuild it. Anybody have an extra? |
| abes914 |
Jun 29 2020, 03:26 PM
| cary |
Jun 29 2020, 10:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Read #4.
Thanks Eric ................. |
| pricebill |
Jul 1 2020, 09:18 PM
Newbie ![]() Group: Members Posts: 5 Joined: 11-October 17 From: Los Angeles Member No.: 21,501 Region Association: None |
Does anyone have a single "marble"? My CV joint came apart earlier today and has only 5 ball bearings (is this a thing that people put these back together with one missing?) Anyway, WTB one bearing, please.
| cary |
Jul 1 2020, 09:24 PM
Really .....
I think I have a qt. container full. Won't be back at the shop till Monday. |
| abes914 |
Jul 1 2020, 09:31 PM
Does anyone have a single "marble"? My CV joint came apart earlier today and has only 5 ball bearings (is this a thing that people put these back together with one missing?) Anyway, WTB one bearing, please. holy cow! mine had only 5 as well! i got one from a friend but i should replace it if they are available. |
| abes914 |
Jul 1 2020, 09:32 PM
| G e o r g e |
Jul 2 2020, 01:03 AM
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None
| pricebill |
Jul 9 2020, 07:40 PM
| abes914 |
Jul 9 2020, 10:16 PM
PM sent. Thank you!
| pricebill |
Jul 10 2020, 12:27 AM
I now have an inkling of why my CV joint was short a ball; with extreme care, you can put this wiggly puzzle together with 5 balls but keeping them all in their channels while placing the 6th is maddening. I watched the Youtube videos for guidance but they were all made on the bench, separated from the axle. Doing so under the car with the race stuck on the end of the axle was an endless game of marbles. Moments after success I quickly bolted it to the transmission flange (with 22ft/lb) and then wept for hours.
| Speedo |
Jul 16 2020, 06:55 PM
Found one thanks guys...back in action.
Lo-Fi Version | Time is now: 19th November 2026 - 10:31 PM |
