> Battery Upgrade, Odyssey PC924 and Aluminum mount
rfinegan
post Jul 10 2020, 10:49 AM
Parts arrived today for the install on my upgrade battery. Odyssey PC924 and Aluminum mount. Just need the terminal kit.
Will post a few pick of the install to follow....
https://www.ebay.com/itm/SR-Battery-Hold-Do...872.m2749.l2649 Streetray 925 mount
-Robert
Replies(1 - 19)
jim_hoyland
post Jul 10 2020, 11:30 AM
Get that VIN ?
Like to see this; getting ready to replace the Optima Red Top....
My red top weighs 38 lb, the 925 is near 24 lb
JamesM
post Jul 10 2020, 11:57 AM
QUOTE(jim_hoyland @ Jul 10 2020, 09:30 AM) *
I have 925s in two of my 914s and a 680 in another other, all using rennline mounts. Havent found anything i like better. Surprisingly, despite being the larger battery I actually find the 925 easier to install/remove due to its lower height. the 925 adds a few pounds over the 680 but either one is still half the weight of a regular lead acid, or the optima (which are garbage these days)
cali914
post Jul 10 2020, 03:37 PM
cali914
Great Battery 159 bucks 13lbs made my own battery mount using top to old battery mount and aluminum channels. This battery available through summitt racing. Attached Image
VaccaRabite
post Jul 10 2020, 07:10 PM
En Garde!
I have a 925 and it does not have enough energy reserves to run lights and wipers at the same time without watching the voltage slowly drop to about 11 volts. Its fine so long as you don't get caught in the rain, but if you do you need to be able to cycle your wipers so the alternator can recharge the bettery.
Zach
wndsrfr
post Jul 10 2020, 07:31 PM
QUOTE(VaccaRabite @ Jul 10 2020, 05:10 PM) *
Zach
Hmmm.... you may need to test your alternator.... seems to me that it should handle lights and wipers without draining the battery...
nditiz1
post Jul 10 2020, 10:37 PM
Crap I just bought the 680, will that be up to snuff? I thought everything could run independent of a battery solely off the alt.
JamesM
post Jul 10 2020, 11:22 PM
QUOTE(nditiz1 @ Jul 10 2020, 08:37 PM) *
Never had a problem at all with my 680.
First year i had the 680 in one of my cars I took it to the RRC in Colorado. Early on the drive home to Salt Lake i somehow lost nut on the lower alternator bolt causing it to back out enough to tweak the angle of the alternator, this resulted in me roasting/throwing several belts to make it home. I thought the 680 performed remarkable well, at times driving for fairly long stretches with no alternator at all on a d-jet car.
Granted I do prefer the 925s for their physical dimensions (and after that trip the added piece of mind of having slightly more reserve capacity) Never had a problem powering anything on the car with any of them though.
I find them to be remarkably resilient too. My oldest 925 I have had over 10 years with no issues. That same 680 just this year I forgot to disconnect before winter and it wound up discharging to where it was reading ~4.5 volts when i got back to it. Charged it back up and its performing perfectly.
JamesM
post Jul 10 2020, 11:28 PM
QUOTE(wndsrfr @ Jul 10 2020, 05:31 PM) *
Zach
(IMG:style_emoticons/default/agree.gif) you may want to look into that. Never had an issue with mine, even running a 680.
Also, get some LED headlights, they will change your world.
gereed75
post Jul 11 2020, 06:10 AM
I run 680 in my airplane. Runs everything no problem and cranks the 360 cubic inch motor like a beast.
925 should be even better
rfinegan
post Jul 11 2020, 06:55 AM
here is the tray ready for the mountAttached Image
rfinegan
post Jul 11 2020, 06:57 AM
and the battery mount
ConeDodger
post Jul 11 2020, 07:11 AM
Apex killer!
QUOTE(rfinegan @ Jul 10 2020, 01:49 PM) *
-Robert
They wear out quick.
80’s old school
post Jul 11 2020, 08:48 AM
I use an 11 pound Braille battery in my 914.
I also use an 11 pound Braille in my Caterham 7 replica and my boat.
They work great.
nditiz1
post Jul 11 2020, 02:52 PM
@JamesM - Can you post a pic of your rennline mount with the 680?
Thanks
Root_Werks
post Jul 11 2020, 08:46 PM
Village Idiot
Run 925's in my Bugs and the 1200 in my 914-6. Work great.
rfinegan
post Jul 12 2020, 06:20 AM
no hole drilling was used to add the mount:
rfinegan
post Jul 12 2020, 06:22 AM
and the hold down side...
snakemain
post Jul 12 2020, 11:18 AM
Ronin Member
My odyssey melted when my VR went bad, along with my Hyfire and some other things. I may get another one when I get my car back.
VaccaRabite
post Jul 17 2020, 09:55 AM
En Garde!
I just pulled the PC925 out of my car and replaced it with a traditional Group 42 lead acid battery.
Couple things that I noticed - the car cranks a little faster.
At idle with lights in wipers running the car sits proudly at ~12.5-13 volts as opposed to the 10.5-11 volts with the 925.
For those wondering about my alternator - I totally went through my electrical system in 2018 when the car stranded me during a drive. New Alternator, alt harness, VR, relay board, cleaned grounds - it was a journey! I can say with some certainty that my charging system is working well.
Here is a thread with information about the LI batteries, draw etc in a 914.
http://www.914world.com/bbs2/index.php?showtopic=342693
If you only drive on sunny days, or live in a place like California where you never really need to use your wipers and it does not get very cold, the batteries like the 924, 925 are probably just fine. But my experience is that if you get caught in a prolonged rainstorm, the 925 does not have the AH to keep up. The wipers (at least my wipers) draw a lot of power.
Another issue that I have the you guys may not - especially if you are carbed. I have modern EFI, and it gets funky if voltage drops. With carbs, you could likely run all day at 10.5 volts and be just fine. I have no real experience driving a 914 with stock injection, so have no understanding of how it would behave. But I know when my car was carbed, as long as I had enough power to run the fuel pump and ignition, the car would go just fine.
I'll keep my 925 and swap it in for AX days and stuff like that, but the Group 42 battery (IMHO) makes a better option for varied street driving.
To each their own,
Zach
- Lo-Fi Version Time is now: 11th October 2026 - 05:52 AM
