> Injector Line Elbow, Fitment and MPS placement
trick-e
post Aug 14 2020, 05:53 AM
Still Learning
Fixing an injector seal leak, thought I’d replace the elbows. Always great stuff from 914 Rubber, so am wondering if they need to be shortened? They are quite a bit longer than the old ones, and have a sharper angle. The problem is they interfere with the MPS placement. If I try to make it work the elbows are pinched at the curve. Seems easy enough to cut off an inch or two, but that doesn’t seem right.
Thoughts?
Replies(1 - 8)
914Sixer
post Aug 14 2020, 06:39 AM
Use your old cloth elbow as a pattern.
trick-e
post Aug 14 2020, 10:16 AM
Still Learning
Agreed. Just seems odd they’re not cut to size. Wondering if I had missed something. Thx
914Sixer
post Aug 14 2020, 02:57 PM
I had another thought about this. I am guessing you need the extra length to put the radius in the hose during manufacturing process.
Mikey914
post Aug 14 2020, 04:16 PM
The rubber man
You are correct.
Kind of like a universal hose you can cut to size.
trick-e
post Aug 14 2020, 07:15 PM
Still Learning
QUOTE(Mikey914 @ Aug 14 2020, 06:16 PM) *
You are correct.
Cut, in place, and we’ll fire it up tomorrow.
Thanks for the info.
trick-e
post Aug 28 2020, 02:29 AM
Still Learning
So, it was a leaking injector body, not the elbow. So I’ve a replacement injector, but need to exchange the cracked elbow. How should I remove the crimped fit while being gentle on the injector?
914Sixer
post Aug 28 2020, 06:16 AM
I used side cutters (dykes), others use dremel tool.
trick-e
post Aug 28 2020, 11:20 AM
Still Learning
Seemed seems obvious, at least now. Thx
- Lo-Fi Version Time is now: 4th July 2026 - 07:16 AM
