Speedo |
Senior Member ![]() ![]() ![]() Group: Members Posts: 559 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains ![]() ![]() |
I am going through my wiring harness post paint and most of my black cloth tape disintegrated. Is there a source for replacing it?
bbrock |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains ![]() ![]() |
It is Tesa tape. You can buy it pretty cheaply on ebay or 914Rubber carries it.
raynekat |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest ![]() ![]() |
There are different widths of the Tesa tape. Look for the smaller widths...something like 1/4" from what I remember.
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I just cut down some hockey tape, it looks like the same cloth tape. $2 a roll.
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,757 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Tangerine Racing has the good stuff. (IMG:style_emoticons/default/beerchug.gif)
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,300 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Tesa 51608, 25m x 19mm adhesive wiring cloth tape?
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
We stock the tape in correct 12mm width
180’ roll Make sure when you compare you check length. There are cheaper at 60’, but you will need 2 and 1/2 rolls. https://914rubber.com/wiring-harness-tape-1 As well as the vinyl tab material for the metal tabs by the ft. As shown Attached thumbnail(s) ![]() |
Lo-Fi Version | Time is now: 31st July 2025 - 05:35 PM |
