Can't close the front hood, Hood will not lock down when closed |
2Lyelo914 |
Jul 13 2005, 10:01 AM
Newbie Group: Members Posts: 18 Joined: 22-July 04 From: Naperville, IL Member No.: 2,384 |
Hood will not lock down when closed. The cable seem functional. The hood goes as the way down. Lubrication is not a problem. Looks like a little wear on the latch in the slot/grove.
I don't really see an adjustment but maybe there is. It was hard to lock before this but a firm hand and correct finger placement on the edge of the front hood worked fine. I certainly don't want to lock it shut forever either. Would appreciate some help and ideas. This is a low milege '74 914 that has never seen a lot of wear or body work. Very clean car so I wonder what is up. TX Jim YELO914 IL |
Joe Ricard |
Jul 13 2005, 10:09 AM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
Is the pull cable sticky. try and push the "T" handle in and then retry the hood. Both teeners I have had seem to do this every once in awhile.
McMark |
Jul 13 2005, 10:31 AM
If pushing the handle doesn't work you can adjust the piece on the body (not the hood) to fit better. Has it closed in the past?
Lo-Fi Version | Time is now: 5th June 2024 - 06:54 AM |
