WTB: Clutch Pedal shaft |
DLewis |
Sep 23 2020, 05:02 PM
Member Group: Members Posts: 63 Joined: 3-December 04 From: Poway, CA (was SF Bay area) Member No.: 3,212 Region Association: None |
Need one to rebuild a cluster.
Old one was frozen on of course, aren't they all. Let me know what you have. Thanks, Dean |
Superhawk996 |
Sep 24 2020, 05:33 AM
914 Guru Group: Members Posts: 5,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
UROpartsman |
Sep 24 2020, 01:23 PM
Member Group: Members Posts: 292 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
We have these in development, but it's still early in the process and will be quite a while before they're available.
bdstone914 |
Sep 25 2020, 09:07 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@UROpartsman
date='Sep 24 2020, 12:23 PM' post='2854005'] We have these in development, but it's still early in the process and will be quite a while before they're available. [/quote] I have had these shafts made with laser cutting of the arm and hand formed. Drill a hole in the shaft and weld the arm to the shaft. Not complex unless you build a stamping die to make the arm. |
UROpartsman |
Sep 25 2020, 11:59 AM
I have had these shafts made with laser cutting of the arm and hand formed. Drill a hole in the shaft and weld the arm to the shaft. Not complex unless you build a stamping die to make the arm. You're absolutely correct, we're working on the tooling to forge the lever arm. Hopefully these will help you with your cluster rebuilds. |
KevinW |
Sep 25 2020, 03:23 PM
Newbie Group: Members Posts: 42 Joined: 25-May 15 From: Winona, Minnesota Member No.: 18,761 Region Association: Upper MidWest |
PM sent
Shipped Attached thumbnail(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 03:25 AM |
