Mike Wofford |
Member ![]() ![]() Group: Members Posts: 68 Joined: 29-April 03 From: Olympia, Wa. Member No.: 629 ![]() |
Question????? Do I set #1 to TDC before I loosen the Rocker arms. I am changing O-rings and need to do a valve adj. when done. Mike
tryan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 553 Joined: 22-January 03 From: smokey mountains gatlinburg tn Member No.: 184 ![]() |
there is a plastic plug next to the oil fill for finding tdc. double check with the dizzy to make sure your not 180 out. spin those push rods on the reinstall to seat them in the lifters
Mike Wofford |
Thanks Tryan, so I need to set #1 to TDC before loosening the rocker assembly.
tryan |
you'll need to get tdc to set the vavles when you get done.
i would do a search on the torque specs for the rocker assemblies and what kind of sealant is recommended for the pushrod o-rings. you might want to download the pdf file. |
Lo-Fi Version | Time is now: 15th June 2024 - 05:10 PM |
