intermitent crank back after one year, 1974 914 1.8 |
brcacti |
Oct 4 2020, 12:06 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
My intermittant cranking is back after one year, was starting well for quite a while. Have power when turn the key but no crank. If I turn the key I can jump start it from the add on starter solenoid with a screwdriver pictured here. Also shown is the relay box, is there anything inside here that I need to check? Wires seem good on the starter
yellowporky |
Oct 4 2020, 02:27 PM
Member Group: Members Posts: 427 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I would clean all of your connections and put some dialectic grease so they don't get corrosion. If that does not clear it up i would suspect the wire from the ignition switch and then the switch.
You are bypassing the relay when you jump the starter with a screwdriver. Also that relay being metal housed i would switch it out for a plastic sealed bosch unit. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:27 AM |
