| shane |
Oct 17 2020, 08:51 AM
Member ![]() ![]() Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
| ndfrigi |
Oct 17 2020, 08:55 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,993 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California
Those allen bolts holds the strut and it will change the alignment. That is where it is being align.
| shane |
Oct 17 2020, 09:11 AM
Those allen bolts holds the strut and it will change the alignment. That is where it is being align. Right allen bolts don’t know why I said nuts, so I’m assuming once you remove them it will slide or something even if you don’t move anything. Just asking cause I’ve never had to remove these before. Thanks |
| JOEPROPER |
Oct 17 2020, 09:17 AM
The answer is "no" unless you ask... ![]() ![]() ![]() Group: Members Posts: 1,209 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States
Yes, they will move. Will need to be re-aligned even if you mark it.
| ndfrigi |
Oct 17 2020, 09:19 AM
Are you planning to change your insert from the strut? If yes, you can just unbolt the center nut by using an impact wrench.
| 914Sixer |
Oct 17 2020, 09:39 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,577 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place.
| bdstone914 |
Oct 17 2020, 09:50 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,393 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Take out one bolt at a time and replace with another 10mm bolt and you will not have to worry about realignment. When you do replace them permenatly use new Schnoor washers.
| shane |
Oct 17 2020, 09:51 AM
I have found IF you leave care firmly on the ground you should be replace the front first and the rear second. This is assuming you have the replacement parts BEFORE you start. Weight of car should keep strut bearing in place. Great idea I’m replating the originals so I’ll just do the fronts first then reinstall them and then do the rears. Thanks |
| bdstone914 |
Oct 17 2020, 12:21 PM
Take out one bolt at a time and replace with another 10mm bolt and you will not have to worry about realignment. When you do replace them permenatly use new Schnoor washers. @shane |
Lo-Fi Version | Time is now: 29th September 2026 - 06:35 PM |
