Throttle body pressure test? |
Slipry |
Oct 25 2020, 09:37 AM
Newbie Group: Members Posts: 20 Joined: 15-September 20 From: New Jersey Member No.: 24,693 Region Association: North East States |
Hand over throttle body while running should stall it ? (Pressure tested?) lol. If it doesn’t stall out than there’s a vaccum leak somewhere?Correct?
sholman5 |
Oct 25 2020, 10:43 AM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
Would thing so, but maybe the AAR valve is stuck in the open position.
Slipry |
Oct 25 2020, 02:26 PM
Aux air R I’ll find it and check it! Thanks
Slipry |
Oct 31 2020, 09:52 AM
Would thing so, but maybe the AAR valve is stuck in the open position. Anyone have a 1975 2.0 vaccum hose diagram? I have a1974 but 75 is different and i can’t find a 75!! Thanks Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Oct 31 2020, 09:58 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
It’s only different in the engine bay location of the charcoal canister. Otherwise the same.
Slipry |
Oct 31 2020, 10:16 AM
It’s only different in the engine bay location of the charcoal canister. Otherwise the same. Trying to find where decel valve gets its vaccum from 2 of 3 connected 1missing could be my vac leak! 74 vac diagram shows pcv in different place and shares vac with decel valve ??? |
Lo-Fi Version | Time is now: 8th June 2024 - 07:38 PM |
