| rspeed2585 |
Nov 26 2020, 08:49 PM
Newbie ![]() Group: Members Posts: 7 Joined: 23-January 14 From: San Diego Member No.: 16,919 Region Association: None |
Does anyone have a contact for a shop that can install steel flares in the So Cal area?
Thank you |
| infraredcalvin |
Nov 27 2020, 12:46 AM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,770 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
http://www.imperialautobody.com/contact.html
These guys did the repair to my rear ended race car. They did some flares for another member some time ago as well... |
| rgalla9146 |
Nov 27 2020, 07:23 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,997 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
| Cairo94507 |
Nov 27 2020, 07:42 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,766 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Be patient. There are many shops in southern CA that can do this job and I am sure other members will reply. Please make sure you select a shop that has done this before so they are correctly located and butt welded. (IMG:style_emoticons/default/beerchug.gif)
| mlindner |
Nov 27 2020, 08:58 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,802 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
Have them follow this if possible, also have the flared rocker for correct placement. Best, Mark
| rspeed2585 |
Nov 27 2020, 09:18 AM
http://www.imperialautobody.com/contact.html These guys did the repair to my rear ended race car. They did some flares for another member some time ago as well... thank you! |
| rspeed2585 |
| rspeed2585 |
Nov 27 2020, 09:19 AM
| rspeed2585 |
Nov 27 2020, 09:20 AM
Be patient. There are many shops in southern CA that can do this job and I am sure other members will reply. Please make sure you select a shop that has done this before so they are correctly located and butt welded. (IMG:style_emoticons/default/beerchug.gif) Thank you I appreciate the advice |
| rspeed2585 |
Nov 27 2020, 09:21 AM
http://www.imperialautobody.com/contact.html These guys did the repair to my rear ended race car. They did some flares for another member some time ago as well... Thank you for the contact! |
| mlindner |
Nov 28 2020, 05:48 AM
And I forgot, if your going to use your steel rockers. Get Ben's flared steel rocker ends to have welded on (mb911). Best, Mark
| rspeed2585 |
Nov 28 2020, 06:55 PM
| Steve |
Nov 28 2020, 07:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,083 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Venice Beach Auto Body aka Beach Boys Racing did mine over 10 years ago. Bob Farnham the owner has retired, so I don’t know if they still do them.
Lo-Fi Version | Time is now: 19th September 2026 - 08:12 PM |
