> Wire for oil pressure sensor, Need to wire oil pressure sensor
Chaznaster
post Dec 2 2020, 08:28 PM
Hi. I have a ‘74 1.8 that is carbuerated. The PO did not have the oil pressure sensor (idiot light) connected. There is only a spade connector coming from the sensor. A lot of wires have been cut back. I read that the sensore wire is red/green. I presume that would be true at both ends (instrument panel and engine bay). Does anyone know where I should be digging to find it? Thanks!
Replies(1 - 3)
JeffBowlsby
post Dec 2 2020, 08:35 PM
It is in the ignition harness. Goes to the relay board.
Chaznaster
post Dec 3 2020, 06:21 PM
QUOTE(JeffBowlsby @ Dec 2 2020, 09:35 PM) *
Found it! Thanks. Now I need figure out where it comes out of the relay board. That is the missing wire. Headed in search of a schematic of a 74 relay board.
JeffBowlsby
post Dec 3 2020, 06:29 PM
It goes to Pin #1 on the 12 pin connector All 914s are identical regarding this. See attached harness diagram specific to your 1974 1.8L harness. The pin #s are cast into the 12 pin connector housing.
Attached File(s)
Attached File  HarnDia_IGN_74_75L_Jet.pdf ( 62.93k ) Number of downloads: 49
- Lo-Fi Version Time is now: 25th August 2026 - 03:44 AM
