Nacho |
Member ![]() ![]() Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None ![]() ![]() |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,060 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
To dampen vibration to the body. Some horn brackets are triple layered. Use a rubber washer too.
Nacho |
bdstone914 |
To dampen vibration to the body. Some horn brackets are triple layered. Use a rubber washer too. Thanks Bruce. My OCD will drive me nuts if I don't locate one or make another ring. Do you have any in your arsenal of parts? Thanks Nacho I dont have any original ones but might have some plastic washers. I am sure McMaster Carr has them. you could probablly get them cheap. |
Nacho |
I've checked McMaster and they don't have them. (IMG:style_emoticons/default/sad.gif)
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I know a guy. Where are these I can check and see if I have a sample should be easy enough if they are what I think they are.
Nacho |
I know a guy. Where are these I can check and see if I have a sample should be easy enough if they are what I think they are. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/aktion035.gif) Thanks -Nacho |
bdstone914 |
How about this one ? I guessed at the thickness. Does it go between the horn and the bracket, or the bracket and body? PET only shows s lock washer on the bolt to the body. I have never seen one of those plastic washers on a horn but PET is not always right. Attached thumbnail(s) ![]() ![]() |
Nacho |
I'll ask for a sample from McMaster and see. update to come later.
-Ignacio |
Mikey914 |
I'll hold tight but if needed pretty simple
bdstone914 |
Mikey914 |
I think it does.
Nacho |
Yes the washer fits inside the hole and does not extend past the thickness of the bracket
Nacho |
bdstone914 |
@Nacho
I pulled one from a horn on my car. I have a bucket of horns somewhere that may have more. There is only one oer horn. |
Nacho |
@Nacho I pulled one from a horn on my car. I have a bucket of horns somewhere that may have more. There is only one oer horn. @bdstone914 Sweet! Can you mail me a few? Or let me know when you'll be around and I can swing by? Thanks Ignacio |
Lo-Fi Version | Time is now: 31st July 2025 - 07:53 AM |
