> Stock 914 CV Geometry, 914 Mid engine sandrail project
GGerg1186
post Dec 7 2020, 09:10 PM
Does anyone have general dimensions for max distance between the outer CV faces at zero, plus twelve, minus twelve degree angles?
I read that the stock 914 CV's are basically the same as a VW type 1, and on blind chicken racing the max angle is 12 degrees.
I have to build custom trailing arms for my sandrail project and need to develop the 3D suspension travel geometry that ensures I do not exceed the CV capacity throughout the range of motion.
If I have to I will just physically measure the parts, but it would be helpful if anyone who has already found this information could share. Yes, I am aware the 3D geometry along with camber, toe, etc needs to be calculated, but these general dimensions will get me 99% of the way there.
Thanks
Replies(1 - 2)
Bleyseng
post Dec 9 2020, 01:11 PM
Aircooled Baby!
I think guys are using 930cv’s for more angle and strength in Syncro Vanagons
Mike Bellis
post Dec 10 2020, 08:49 PM
Resident Electrician
Swap over to 930 CV's or you are asking for trouble. You may also want to go non-plunging with sliding axles.
https://www.pacificcustoms.com/axles.html
https://www.rcvperformance.com/ultimate-930...-28-spline.html
- Lo-Fi Version Time is now: 1st May 2026 - 08:14 PM
