944 & VW Bus CV's, Thickness Difference |
914Sixer |
Dec 14 2020, 04:03 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just thought I would pass this along. Today I was checking on the CV joints I was going to use on the full floating axles. I am using 911SC hubs, stub axles and 915 transmission flanges. The whole set up is 100mm 6 bolt. 944 CV conversion is over in the classic section. So, I got the joints out to compare, both are Lobro and have the same part number BUT they are different thickness. The LATE 944 are 34mm thick and the OLD (1978) Bus CV's are 32. Make sure all 4 of your CV's are the same thickness IF you are cutting your stock axles to to 944 conversion. NO problem if you are using floating axles.
MM1 |
Dec 14 2020, 04:50 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
Thanks for sharing, Mark.
914Sixer |
Dec 14 2020, 09:01 PM
Added chart from Blind Chicken Racing CV 101 for additional information. Looks like the 944 is the same thickness as the VW Type4 with more articulation than the VW Bus.
Click to open chart. Notice that the 94mm (914) only has 12 degrees and the 944 goes a full 10 degrees more at 22 . Attached thumbnail(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:44 PM |
