| metalvolks |
Dec 20 2020, 01:23 PM
I'm new here ... Group: Members Posts: 0 Joined: 7-December 20 From: San Diego, CA Member No.: 24,961 Region Association: Southern California |
SOLD! SOLD! Hello everyone! Below is a complete list of 914 parts that I have for sale AS A LOT - I'm not really interested in parting pieces of it out any more.
I am looking to get $50 if you take everything listed below. I have hundreds of photos organized on a webpage with the link below. Everything sold as-is. Please take a look at the site before you contact me. Disregard the prices on the site. PICTURES OF ALL PARTS BELOW ARE HERE! http://paulmichaelrogers.com/porsche914parts/ Available Parts List: Engines/Engine Mechanical Parts: Engine Tin (1/2 Side Tin - 3 1.7/1.8, (4 Rear Tin), (Misc. Tin). Condition ranges from fair to good. Thermostat 2.0 Air Cleaner Housing - Surface Rust, but overall good condition Cooling Shroud (Good Condition) Muffler A/C Compressor (York) Stock (unknown condition) 1.7 (2 sets)/1.8/2.1 Cylinders (90 (2 sets) /92/96mm) - 92mm Cylinders and 96mm Cylinders SOLD, Pistons and Pins (most cylinders in good shape-all need to be honed. A few pistons have gouges and nicks. Pins would need to be polished) Pressure Plates Camshafts Crankshafts (Don't know for which motor) Engine Support Cross Bars - early style, later style 1.7 & ('74 1.8) Muffler Bracket Engine Electrical Parts: Engine Compartment Heater Blower Motor (TESTED-WORKING) 1 Alternator (with Cooling Vent) Interior/Mechanical: Shifter Seat Bracket Interior: Passenger Door Pulls Driver Door Pocket (Blue) A-Pillars - Poor to Fair Condition Ash Tray Driver Door Pocket Covers - Fair Condition Rear View Mirror - Fair Condition (Glass Issues) Upper Windshield Trim - Fair Condition Carpet Sill Trim Lot Seat Belt Receivers Misc. Interior Vents Dash Trim Plate - Very Straight Center Console Shifter Panel/Trim/Cover & Defrost Switch Console Box (Fair Condition) Body/Electrical: Tail Lights (2 lefts, 1 right) - Poor to Fair Condition (usable) Front Turn Signal Housings - Fair to Good Condition Horn Headlight Motors Headlight Assembly Lot - Fair Condition Fog Light Grill - Poor to Fair Condition (2 Cracks) A/C Evaporator, Fan and Enclosure DPD Misc. Relays, Switches, Actuators (Unknown Condition) Rear License Plate Lights Body: Rain Trays (2) - Both Have Small Cracks (can be fixed easily) License Plate Bracket Bumper Guards (Good Useable Condition) Spare Tire Well Section Brakes: Front Backing Plates - Good Condition Suspension: Aftermarket Unknown Brand Springs - Very High Spring Rate it Appears (Pair) Stock Rear Springs - 3 Red Stripes (2 Pair) Spring Hats, Seats & Hardware (Lot) Tie Rods Front Suspension, uprights, spindles, backing plates, crossmember Glass: 1969-1972 Driver's Window - Good condition Rear Glass - Good condition Misc.: Fuel Tank Fuel Tank Bumpers Windshield Washer Bottles Fuel Expansion Tanks (1 Plastic, 3 Metal) Charcoal Canister (2) Hood Springs and Hinges Factory Lug Wrench Thank you for looking! Paul SOLD parts list from this post: SOLD - OEM Oil Cooler - Good Condition - $40 SOLD - Cooling Shroud w/Alternator - Good Condition (small crack) - $40 SOLD - 2.0 Passenger Heat Exchanger - fair condition - $80 SOLD - 1.7/1.8 Stainless Steel Heat Exchangers (smoke tested ok) - Great Condition - $650 SOLD - 1.7 Long Block with heat exchangers (Complete Engine minus carbs, intake, distributor. Unknown Condition, Spins Freely - $450 SOLD - 1973 1.8 EC Case, Crank, Rods, Cam and Oil Pump - Good Condition - $200 SOLD - OE Oil Pump - 021 115 109A - $30 SOLD - 2.0 Oil Pickup and Windage - $40 SOLD - 1.7/1.8 Heat Exchangers (smoke tested ok) - Good Condition - Surface Rust and Paint, but solid - $150 SOLD - 1.8 Heads - Good Condition (No Visible Cracks) - 021 101 371 S - $120 (Set) SOLD - 2.0 Heads - Bare - 1 Head Great Condition (no cracks), 1 Head Machining Needed (Valve Seat Damage, 1 broken fin and 1 bent fin) - $250 (Pair) SOLD - Flywheel - $40 SOLD - Connecting Rods - $40 SOLD - Smog Pump - $40 SOLD - Engine Parts Lot1 (rocker arms, lifters, pushrods, springs, gaskets, etc) - $50 SOLD - Early 2.0 Muffler Bracket - $20 SOLD - Bosch Blue Coil - $20 SOLD - Pedal Board (Decent Condition) - $40 SOLD - 1973 914 Rolling Shell - Mainly surface rust. Hellhole, Rockers, Longs, Floors, Battery Tray, etc. solid. Small hole in floor, battery tray, spare tire well and trunk. Left Rear Shock Tower Needs Replacement. Has suspension, 5 steel "sport wheels", passenger windows and mechanism, etc. - $600 Engine Compartment Covers - $40 (white one is SOLD) SOLD - Engine Compartment Cover (Complete) With Rain Tray (Great Condition-No Dents) (Early Model) - $250 SOLD - Targa Top (Good-Usable Condition - small chip on corner - w/Front Latches) - $100 SOLD - Targa Top (Good Condition - w/ 1 Front Latch) - $125 SOLD - Front Hood (Great Condition - no dents, light surface rust, latch) - $125 SOLD - Dash Frame (Good Condition) - $80 SOLD - Front Bumper (Chrome Painted Black - Fair Condition) - Fairly straight with only a few dents- $80 SOLD - Rear Valance - poor to fair condition - $20 SOLD - Rear Calipers (Good Condition-Needs Rebuild) - $30/each SOLD - Rear Backing Plates - Fair Condition - $15/each SOLD - Weltmeister SP100 Rear Springs (Pair) - $60 SOLD - Wiper Arms Lot - $10 SOLD - 1 Alternator (with Cooling Vent) - $20 SOLD - Oil Filter Mounting Console - $15 |
| rcarson25 |
Dec 20 2020, 03:16 PM
Member ![]() ![]() Group: Members Posts: 62 Joined: 15-May 17 From: TN Member No.: 21,103 Region Association: South East States
I know he is new here at 914world, but I have known Paul for years. He is a good guy and good seller so you can buy with confidence.
| 914sgofast2 |
Dec 21 2020, 12:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 814 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
PM sent for 1.8L heads, oil pickup & windage teay, oil pump, and passenger door pocket.
| frostyf |
Dec 21 2020, 12:23 PM
Member ![]() ![]() Group: Members Posts: 155 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region
Hi Paul, PM'd you about weltmeister SP100 Rear Springs (Pair) - $60
And bilstein shocks. Nick |
| porscheaddic |
Dec 21 2020, 12:31 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 9-July 07 From: california Member No.: 7,898 |
Hi Paul,
Sent you a pm regarding the rods, and rear brake calipers. Thanks, Vince |
| jdbogart@self-serv.net |
Dec 21 2020, 03:55 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 17-July 19 From: California Member No.: 23,305 Region Association: Southern California
Hi Paul -
I'm looking for the D-ring with the short fabric strap that leads to underneath the speaker housing. It would be for a 1970-71 914 removable footrest. Opposite the D-ring on the strap would probably be a hole for a speaker housing screw to go through. Thanks Don |
| metalvolks |
Dec 21 2020, 04:40 PM
| metalvolks |
| metalvolks |
| metalvolks |
Dec 21 2020, 04:42 PM
I know he is new here at 914world, but I have known Paul for years. He is a good guy and good seller so you can buy with confidence. Thanks Ryan and thanks everyone for the interest in the parts. Please remember to view all the pictures for each part via the link I provided in the ad (I had so many pictures it would have been a nightmare to add them all to 914world). Click on each part and then click on each picture to view a high def picture. Paul |
| second wind |
Dec 21 2020, 04:58 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 862 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California
Hello Paul.....I would like dibs on the 2.0 stainless steel heat exchanger.....thank you very much.
gg |
| metalvolks |
Dec 21 2020, 05:12 PM
| Ampex351 |
Dec 21 2020, 05:45 PM
Member ![]() ![]() Group: Members Posts: 104 Joined: 8-April 20 From: Roseburg, Oregon Member No.: 24,115 Region Association: Pacific Northwest |
Paul, I need that antenna off of the white 914 body. Complete with the rubber base.
Thanks, Roger |
| metalvolks |
Dec 21 2020, 06:01 PM
| second wind |
Dec 21 2020, 10:31 PM
[quote name='metalvolks' post='2877018' date='Dec 21 2020, 03:12 PM']
[quote name='second wind' post='2877016' date='Dec 21 2020, 02:58 PM'] |
| metalvolks |
Dec 23 2020, 03:13 PM
Friendly bump (IMG:style_emoticons/default/smile.gif)
| metalvolks |
Dec 27 2020, 11:08 PM
Another Friendly Bump!
| Ampex351 |
Dec 28 2020, 12:35 AM
| metalvolks |
Dec 28 2020, 01:17 AM
| 930cabman |
Dec 29 2020, 05:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,834 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Are the rear calipers and backing plates available? If so, I will take them.
thank you |
Lo-Fi Version | Time is now: 25th September 2026 - 07:51 AM |
