Heater/fan control trim removal |
EJP914 |
Dec 28 2020, 09:37 PM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
Hello,
Need some advice on how to remove the chrome trim that goes around the heat air control panel on the dash. Any special or even goofy tools you can recommend I can use without bending up the chrome piece? If I remember right from prior 914's, there is a tab at each end and 2 on the top and bottom. Is that chrome piece attached to the heater fan control face plate or is it separate? Thought if I removed the nut underneath that is attached to the front bulkhead, the entire assembly could be pulled forward INCLUDING the chrome trim. Maybe not? Thanks in advance for the help. Ed |
partwerks |
Jun 15 2021, 05:27 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I was wondering the same?
ClayPerrine |
Jun 15 2021, 05:38 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There is a 6x1.0 stud on the front wall under the dash that holds the heater control in the dash. Remove the nut from it and pull the heater control out of the dash. Once out, you can remove the chrome trim easily.
Clay |
partwerks |
Jun 15 2021, 08:09 PM
I got it out............
ClayPerrine |
Jun 16 2021, 09:55 AM
Lo-Fi Version | Time is now: 8th June 2024 - 03:17 AM |
