Joe Simon |
Newbie ![]() Group: Members Posts: 13 Joined: 7-May 19 From: New Jersey Member No.: 23,102 Region Association: None ![]() |
I am trying to source an origina 914/6 combo gauge. I have found several and they all have part number 914 641 101 10. The Porsche 914-914/6 Classic Parts Catalog lists the part number as 914 641 101 20. I called my local Porsche dealer to try and verify these part numbers. The 914 641 101 20 comes up as the OEM Gauge for 914/6 as discontinued. Part Number 914 641 101 10 comes up as a factory Gauge with no designation as to model, also discontinued. The Gauges with the 10 designation look right, could it be this was the original part number in 1970 and replaced as a over the counter part number with a 20 designation?
barefoot |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,411 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States ![]() ![]() |
Can't find neat site that documents 914 gauges, but there are with & W/o oil temp gauge insert, as well as silver dot, non silver dot options
Good luck ! |
fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
Just looked at mine, factory -6, Mar '70.
Gauge p/n 914 641 101 10 |
poorsche914 |
T4 Supercharged ![]() ![]() ![]() ![]() Group: Members Posts: 3,139 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States ![]() |
Can't find neat site that documents 914 gauges, but there are with & W/o oil temp gauge insert, as well as silver dot, non silver dot options Good luck ! Found this info on p914.org... but all links point to p914.com which for some reason does not load. So, replace .com with .org and the page loads fine. 1970 - 1972 Porsche 914/6 Combo Gauges (IMG:style_emoticons/default/driving.gif) |
Joe Simon |
FlacaProductions |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,970 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California ![]() ![]() |
Just fyi for anyone looking - appears that Brad Mayeur has a very nice -10 unit on ebay:
https://www.ebay.com/itm/Porsche-914-6-Fuel...R4AAOSwc4pf--K1 |
Joe Simon |
[quote name='poorsche914' date='Jan 11 2021, 06:27 PM' post='2882120']
[quote name='barefoot' post='2882079' date='Jan 11 2021, 02:23 PM']Can't find neat site that documents 914 gauges, but there are with & W/o oil temp gauge insert, as well as silver dot, non silver dot options Good luck ![/quote] Found this info on p914.org... but all links point to p914.com which for some reason does not load. So, replace .com with .org and the page loads fine. 1970 - 1972 Porsche 914/6 Combo Gauges Thank you for your in depth research on my request to clarify the part numbers on a 914/6 Combo Gauge. I appreciate you doing this and now can source the correct Gauge with confidence |
Lo-Fi Version | Time is now: 12th July 2025 - 04:53 PM |
