> OT Epoxy Resin cars
Unobtanium-inc
post Jan 14 2021, 07:05 PM
Me and the kids decided to start playing with Epoxy Resin. Avi made little tea cups, I made Porsches!
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
3 Pages V  1 2 3 >
Replies(1 - 19)
Mikey914
post Jan 14 2021, 08:06 PM
The rubber man
Silicone works much better. It's how we started making parts. Very time consuming but fun.
Unobtanium-inc
post Jan 14 2021, 08:28 PM
QUOTE(Mikey914 @ Jan 14 2021, 06:06 PM) *
I made the mold with silicone, man was it stinky!
post Jan 14 2021, 09:03 PM
Dow RTV gr8 stuff
Tdskip
post Jan 14 2021, 10:04 PM
Very cool
jrblackbox
post Jan 15 2021, 10:20 AM
QUOTE(Unobtanium-inc @ Jan 14 2021, 06:05 PM) *
What no 914??
Mikey914
post Jan 15 2021, 10:27 AM
The rubber man
Undercut on the windshield with top off was to much (IMG:style_emoticons/default/beerchug.gif)
Unobtanium-inc
post Jan 15 2021, 11:03 AM
QUOTE(jrblackbox @ Jan 15 2021, 08:20 AM) *
What no 914??
Next round, it's so easy I'll be doing a bunch.
Unobtanium-inc
post Jan 16 2021, 03:06 PM
Ok, so after polishing and clear coating, this is where we are. I'm trying some more refinements, but overall it's fun!
VaccaRabite
post Jan 17 2021, 04:14 PM
En Garde!
You need to rig up a vacuum chamber or a pressure pot to out gas all those bubbles.
Zach
Unobtanium-inc
post Jan 17 2021, 08:25 PM
Tried to do black resin, worked out ok, but I kind of like the clear better. Might experiment with lite tinting, rather than solid colors.
Also, ran out of resin, so ordered 2 gallons, it's gonna be a long winter.
Spoke
post Jan 17 2021, 08:39 PM
Jerry
Looks good. I like both the clear and the black. I'll take a 930 in clear if you're selling any... (IMG:style_emoticons/default/beerchug.gif)
Unobtanium-inc
post Jan 19 2021, 08:09 PM
Ok, made a new mold tonight and yes there is a 914 in there!
Hoping to do all these this weekend, check back for updates.
infraredcalvin
post Jan 20 2021, 08:34 PM
Distracted Member
Can you make some ice cube trays out of those? That would be slick!
flat4guy
post Jan 20 2021, 09:33 PM
Looks like fun - how heavy are they? I wish we had winter in Calif - I was doing yard work in a T shirt today.
Unobtanium-inc
post Jan 20 2021, 10:46 PM
QUOTE(flat4guy @ Jan 20 2021, 07:33 PM) *
They are lighter then they look.
And mold making is harder then I thought, I must have gotten lucky with my first one because I've failed on the last two. Shooting for number 3 this weekend.
Unobtanium-inc
post Jan 24 2021, 07:12 PM
So after three tries to make a larger mold for more cars, and three failures I went back to the drawing board. More research showed me an alternative method to making the mold that looked very promising, and a lot less work and mess. It involved DAWN soap and water, pretty simple, right? I tried and it was much easier. I poured resin in the new molds so tomorrow we shall see if the finished result is better. But I now have 11 car molds, so everything from a 917, to a Speedster, to a RSR. One drawback, the new method take all the paint off the little cars in the mold making process. Strange byproduct.
Stay tuned.
Unobtanium-inc
post Feb 3 2021, 09:25 PM
Ok, so lots of trial and error later, more error actually. I've upgraded the mold making twice and am much happier with the latest results, shiny and crisp, without any buffing or sanding. I'll keep working but the process is improving, and I'm still having fun!
burton73
post Feb 3 2021, 11:17 PM
Senior member, and old dude
If your mold and material is very cold and the pouring area is cold you can have problems. Pre-warm up the molds and material to a nice 80 or 90 degrees or more and it will help. Also, if you have a vacuum chamber for some reason, mix, and then deair the mix for a couple of minutes and pour slowly in the mold. The very small bubbles will come out in the chamber Part of that combo is used for A/C system but the pot can be a modified 3 paint pot.
You can also use a paint pot and set it up for 30lb PSI. The bubbles will get so small that you will not see them but you have to leave the pressure on for a long time to make sure the plastic is hard. If not hard the bubbles will show.
I just put my pressure on the compressor line and leave it overnight and open it up in the AM
Been casting this way for 46 years.
Bob B
3 Gallon Vacuum Chamber and 3 CFM 1 Stage Pump to Degassing Stainless Steel
Set up is like $100.
Unobtanium-inc
post Feb 4 2021, 06:38 AM
QUOTE(burton73 @ Feb 3 2021, 09:17 PM) *
Bob B
Thanks for the tip!
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 11th November 2026 - 10:39 AM
