front defroster motor |
914andy |
Jan 20 2021, 10:20 AM
Member Group: Members Posts: 59 Joined: 23-December 11 From: Nashville tn Member No.: 13,929 Region Association: None |
Hi All
out and about in my -6 today and the defroster motor has decided to run wide open. no documentation with me so I'm trying to find out where to kill the power at....is there a fuse or relay I can pull till I get home? thanks Andy |
rgalla9146 |
Jan 20 2021, 11:43 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Fuse # 8 25 amp wipers, ventilator, horn, cigarette lighter
The three speeds are controlled by sliding contacts behind the dash HVAC panel. The plastic holder is often melted and deformed by partial contact between speed contacts. The next suspect is a resistor inside the heat /defrost box. Neither job is a pleasure. Attached thumbnail(s) |
914andy |
Jan 20 2021, 11:58 AM
thanks
Andy |
Lo-Fi Version | Time is now: 11th June 2024 - 10:23 AM |
