914 Trivia questions |
JeffBowlsby |
Jan 20 2021, 07:37 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
As an effort to get more acquainted with your 914. Illustrate your answer with a posted photo. Please feel free to add your trivia question to this thread:
1. Standing in front of your 914 looking back at it, directly at the headlights, with headlights raised and lights off and the perimeter shroud installed, what is the location of the screws to adjust each headlight aim? A.) Two screws both headlights, at top and bottom B.) Three screws in a triangular layout around the headlight C.) Two screws both headlights, at top and left D.) Two screws at top on both headlights, at left on the passenger side, and at right on the drivers side |
ClayPerrine |
Jan 20 2021, 08:48 PM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
As an effort to get more acquainted with your 914. Illustrate your answer with a posted photo. Please feel free to add your trivia question to this thread: 1. Standing in front of your 914 looking back at it, directly at the headlights, with headlights raised and lights off and the perimeter shroud installed, what is the location of the screws to adjust each headlight aim? A.) Two screws both headlights, at top and bottom B.) Three screws in a triangular layout around the headlight C.) Two screws both headlights, at top and left D.) Two screws at top on both headlights, at left on the passenger side, and at right on the drivers side D |
mmichalik |
Jan 20 2021, 11:26 PM
MikeM Group: Members Posts: 702 Joined: 27-January 16 From: Valley Center, CA Member No.: 19,600 Region Association: Southern California |
As an effort to get more acquainted with your 914. Illustrate your answer with a posted photo. Please feel free to add your trivia question to this thread: 1. Standing in front of your 914 looking back at it, directly at the headlights, with headlights raised and lights off and the perimeter shroud installed, what is the location of the screws to adjust each headlight aim? A.) Two screws both headlights, at top and bottom B.) Three screws in a triangular layout around the headlight C.) Two screws both headlights, at top and left D.) Two screws at top on both headlights, at left on the passenger side, and at right on the drivers side B |
FJ1200 |
Jan 20 2021, 11:39 PM
Member Group: Members Posts: 61 Joined: 26-December 18 From: Harpswell, ME Member No.: 22,751 Region Association: North East States |
None of the above
Olympic 914 |
Jan 21 2021, 08:39 AM
Group: Members Posts: 1,676 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
C
No shrouds attached, But you can see the nylon adjusting blocks in this photo. |
JeffBowlsby |
Jan 21 2021, 09:15 AM
C No shrouds attached, But you can see the nylon adjusting blocks in this photo. C is correct. Both headlights adjust the same, top and left., without needing to remove the shroud. Next trivia question? Attached image(s) |
Jamie |
Jan 21 2021, 10:11 AM
Senior Member Group: Members Posts: 1,035 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
As an effort to get more acquainted with your 914. Illustrate your answer with a posted photo. Please feel free to add your trivia question to this thread: 1. Standing in front of your 914 looking back at it, directly at the headlights, with headlights raised and lights off and the perimeter shroud installed, what is the location of the screws to adjust each headlight aim? A.) Two screws both headlights, at top and bottom B.) Three screws in a triangular layout around the headlight C.) Two screws both headlights, at top and left D.) Two screws at top on both headlights, at left on the passenger side, and at right on the drivers side Trick question, if headlights are off, the lights would not be raised? (IMG:style_emoticons/default/confused24.gif) |
Shivers |
Jan 21 2021, 10:27 AM
Senior Member Group: Members Posts: 2,431 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
oops, darn it
double-a |
Jan 21 2021, 11:13 AM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
C
Lo-Fi Version | Time is now: 9th June 2024 - 09:57 PM |
