Throttle Cable Barrel Nut?, is this the same part? |
Calwaterbear |
Jan 26 2021, 12:53 PM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
Ok guys, I'm looking for the "barrel nut" thing that adjusts the throttle cable and holds it into place.
unfortuntely I don't have an original to compare . is this it? Pelican parts https://www.pelicanparts.com/More_Info/3111...amp;SVSVSI=5874 or aftermarket? I do like that it is shown with the bolt/screw included https://www.pelicanparts.com/More_Info/3111...amp;SVSVSI=5874 I'm a bit confused because these are identified as Heater Cable barrel nuts, so I'm thinking / hoping it gets used in both places? |
914Sixer |
Jan 26 2021, 02:01 PM
914 Guru Group: Members Posts: 8,912 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Heater barrel nuts ARE different than throttle barrel nut
bdstone914 |
Jan 26 2021, 03:50 PM
bdstone914 Group: Members Posts: 4,545 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Heater barrel nuts ARE different than throttle barrel nut Mark, Yes they are different but I see no reason why the heater barrel nut will not work in the throttle linksge. I think it is slightly longer. @914sixer |
Lo-Fi Version | Time is now: 17th June 2024 - 01:25 PM |
