Distributor, Reinstalling |
EJP914 |
Jan 30 2021, 09:37 AM
Member Group: Members Posts: 260 Joined: 14-June 03 From: Monroeville, PA Member No.: 821 |
After a couple of days of PB Blaster, prying, lots of profanity, etc, it finally came out.
When I put the distributor back in, should the O ring, distributor bore and shaft be lightly coated with oil or something to help it slide back in? Thanks Ed |
dr914@autoatlanta.com |
Jan 30 2021, 10:03 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes you can coat with lithium grease
After a couple of days of PB Blaster, prying, lots of profanity, etc, it finally came out. When I put the distributor back in, should the O ring, distributor bore and shaft be lightly coated with oil or something to help it slide back in? Thanks Ed |
Lo-Fi Version | Time is now: 10th June 2024 - 06:50 AM |
