new parts for the bottom of the fuel gas tank, direly needed pipes and aluminum nuts |
dr914@autoatlanta.com |
Feb 5 2021, 12:23 PM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
We are in the process of making the parts shown, We had been making the nuts both large and small hole as you can see but are now making the pipes as well since we have no more good used and of course the factory has discontinued it
These will go well with Tangerine racing stainless fuel lines, and of course we first asked Chris if he wanted to make them, but he said he was too busy. The nuts are original aluminum and we will make the pipes out of stainless to match Chris' fuel lines. Please note, 70-74 use one 7mm pipe and one 9mm pipe, 75 76 with the push type front mounted fuel pump use 2 7mm pipes |
brcacti |
Feb 5 2021, 03:38 PM
1974 914 1.8 Group: Members Posts: 674 Joined: 17-July 19 From: PHX AZ 60 miles south Member No.: 23,302 Region Association: Southwest Region |
Thank you George, hope you're enjoying your hobbie and business is thriving.
StarBear |
Feb 5 2021, 03:52 PM
Senior Member Group: Members Posts: 1,913 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
roundtwo |
Feb 5 2021, 04:11 PM
Member Group: Members Posts: 282 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Lo-Fi Version | Time is now: 10th June 2024 - 06:25 PM |
