Sorensen injector 1.7 any good?, I'm desperate |
Sprout |
Mar 11 2021, 04:10 PM
Member Group: Members Posts: 125 Joined: 5-October 18 From: Kansas City Member No.: 22,544 Region Association: Upper MidWest |
Anybody used these: 800-1108n before? Any good?
914Sixer |
Mar 11 2021, 07:18 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
New or rebuilt?
Sprout |
Mar 11 2021, 08:03 PM
Sprout |
Mar 11 2021, 08:28 PM
Came across this thread discussing the Standard Motor Products injectors and the good flow test that was done on the FJ67 by Mr. Injector, so found their FJ114 injectors for 1.7 and ordered. Fingers crossed!
http://www.914world.com/bbs2/index.php?sho...amp;hl=sorensen |
914Sixer |
Mar 12 2021, 07:13 AM
You should be good to go.
Jmkorfha |
Mar 12 2021, 02:13 PM
I'm not a singing grandpa. Group: Members Posts: 59 Joined: 26-October 13 From: Austin, Mn Member No.: 16,569 Region Association: Upper MidWest |
I put one in last year. Worked perfectly.
Sprout |
Mar 16 2021, 06:48 PM
Thanks, all! I got the FJ114 and SK3 seal kit. Installed and running great. Even if it lasts half as long as the Bosch's 48 years, I'll be happy!
https://www.amazon.com/Standard-Motor-Produ...1750&sr=8-2 |
sjhenry1075 |
Mar 17 2021, 07:27 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Jmkorfha |
Mar 17 2021, 08:42 PM
I put one in last year. Worked perfectly. When you say you put "one" in, you meant that you only replaced one of your injectors, correct? I will be doing the same thing but was unsure how it would work with the others (that are different). Yes. One of my originals was leaking between the plastic and metal body. I installed one new one from autozone and it runs perfectly. |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:23 AM |
