Torque Spec Needed, Rear Brakes |
Ansbacher |
Mar 17 2021, 12:37 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks.
Ansbacher |
mepstein |
Mar 17 2021, 01:12 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Really tight. Just kidding sort of. It's a tough spot to put a torque wrench on.
JeffBowlsby |
Mar 17 2021, 01:39 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
914e |
Mar 18 2021, 12:48 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks. Ansbacher According to the Tech Specs book: M12 x 1.5 x 30? 7.0 ft lbs I think that is meter kilopond It should be 50 ft lbs |
bdstone914 |
Mar 18 2021, 06:54 AM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks. Ansbacher According to the Tech Specs book: M12 x 1.5 x 30? 7.0 ft lbs I cant believe it is 7 ft lb. Did you add a decimal in error? @JeffBowlsby |
Mark Henry |
Mar 18 2021, 07:54 AM
JeffBowlsby |
Mar 18 2021, 08:17 AM
Anyone know the torque spec for the 19 mm caliper retaining bolts on the rear brakes? Car is a '74 2.0 . Thanks. Ansbacher According to the Tech Specs book: M12 x 1.5 x 30? 7.0 ft lbs I cant believe it is 7 ft lb. Did you add a decimal in error? @JeffBowlsby You're right Bruce I should have questioned that. Turns out its more likely "7.0 mkg" = 50 ft lbs. Of the several torque value tables in the Tech Specs book, only one has the units mkg indicated all other tables do not show units. Attached image(s) |
Ansbacher |
Mar 18 2021, 10:45 AM
Thanks everyone for clearing this up. Now, if I could just find my torque wrench.... (IMG:style_emoticons/default/headbang.gif)
Ansbacher |
brant |
Mar 18 2021, 10:47 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
also... don't the rear calipers have the locking tab... that prevents those bolts from loosening....
I never use a torque wrench on them good and tight has always worked. and then the lock tabs b |
mepstein |
Mar 18 2021, 11:15 AM
bdstone914 |
Mar 18 2021, 01:23 PM
also... don't the rear calipers have the locking tab... that prevents those bolts from loosening.... I never use a torque wrench on them good and tight has always worked. and then the lock tabs b @brant Fronts have the lock tabs. I toss them and use wave washers like all other Porsche calipers use Rears have the backing plate strap that goes between the caliper rear and trailing arm. If left out the caliper rubs. |
iankarr |
Mar 18 2021, 01:42 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,481 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Backing plate strap?
brant |
Mar 18 2021, 03:05 PM
good point.. and I wasn't very clear.
I was thinking the rear backing straps too I just use split washers on my front calipers also. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:28 AM |
