> 914 ITB's, Pro's and Cons, option opinions and show us your setup!!
Steve
post Mar 23 2021, 02:15 PM
It seems like ITB's are all the rage with our air cooled sixes.
The throttle bodies are either PMO or direct to head either with butterflies or AT-Power with no butterflies.
Mark dug up some of the pricing!! Thanks Mark!!
X-Faktory uses Megasquirt, Link or Motec M84
https://www.x-faktory.com/uploads/6/3/9/3/6...efi_systems.pdf
Starting at $4754
Clewett uses TEC
https://www.clewett.com/index.php?main_page...dex&cPath=2
Starting at $8400
Rasant uses exclusively Motec, which is the most expensive
https://rasantproducts.com/collections/mote...84-ecu-packages
Starting at $5700 for the ITB's and $6200 for the EFI
AT-Power offers throttle bodies without butterflies, but use special cams to optimize
https://www.atpower.com/
Starting at $13K
Lots of options which can raise or lower the price.
I have a stock Euro 3.2 with DME that does run fine, but I miss the sound of the webers, but I don't miss the hassle of webers, cold start, poor gas mileage, etc.
I know ITB's are expensive, but option 2 at X-Faktory is not that bad and pretty popular over on the Pelican 911 technical forum.
Anybody on this forum have any experience with any of these toys?
Replies(1 - 19)
roblav1
post Mar 23 2021, 03:01 PM
I had an 84 911 with a 3.2 and altered and installed Suzuki GSX-R 750 throttle bodies with Megasquirt. It ran but never did get it right. I then installed Weber 40 IDAs and was immensely disappointed. IMO, it needed bigger camshafts and a "real" exhaust to get the feel of early S and E engines. I sold the car just before doing my 1st 914 993 conversion.
michelko
post Mar 23 2021, 03:04 PM
I did my setup with triumph speed triple throtzle bodies.
The ecu is an megasquirt 2.
Works nice after fidling out some issiues.
Much better thsn the zenith carb i previous had on the 2.4 engine.
Michael
post Mar 23 2021, 03:22 PM
914-6 GT in waiting
Slippery slope (IMG:style_emoticons/default/biggrin.gif)
worn
post Mar 23 2021, 03:31 PM
QUOTE(Steve @ Mar 23 2021, 12:15 PM) *
Have to say that I really like the part where the 3.2 runs fine. I really like driving that car...but I am also an old fart, mostly in the way of things.
Steve
post Mar 23 2021, 03:36 PM
QUOTE(mepstein @ Mar 23 2021, 02:22 PM) *
If your going for horsepower than your better off upgrading to a 3.6 from a 3.2. Probably around the same price. The hp gains from ITB’s on a stock motor are around 20 hp for a 3.0 or 3.2 motor. Best gains seem to be on a CIS motor.
Steve
post Mar 23 2021, 03:43 PM
QUOTE(worn @ Mar 23 2021, 02:31 PM) *
I feel the same way. If it ain't broke don't fix it. It's also a lot of work to swap it out for ITB's and probably very expensive to let someone else do it, but they do sound awesome!!
post Mar 23 2021, 04:37 PM
914-6 GT in waiting
QUOTE(Steve @ Mar 23 2021, 05:36 PM) *
I think you usually go for itb’s so you can use more aggressive cams, compression, etc. Peter Dawe said the stock manifold is good for up to 300hp. We have an engine at the shop with 290 rear wheel hp that he helped to build. It has itb’s, but is a 3.5 built on a 3.2 case.
There is a good market for used 3.2 parts but from just a HP perspective, the conversion doesn’t make $ sense. If it makes you happy, then it’s worth it.
Luke M
post Mar 23 2021, 04:59 PM
On my 3.4 build I went with the Rasant Products/PMO ITB's just to keep it kinda factory looking. Not sure how it's gonna work out as I have other things to do before I get there.
Oh yeah it's not a cheap setup either. Hopefully it all works well.
Steve
post Mar 23 2021, 05:16 PM
QUOTE(Luke M @ Mar 23 2021, 03:59 PM) *
Why did you choose Rasant over the other vendors? Most of the other vendors offer PMO ITB's with there lower cost Engine Management Solutions.
Luke M
post Mar 23 2021, 06:00 PM
QUOTE(Steve @ Mar 23 2021, 04:16 PM) *
I asked over on the bird site which was the better product. Rasant came in on top for a quality product and customer service. I also got the COP, better ecu, just a complete bolt on kit. I wanted the Org look of carbs but not the headaches of tuning them.
Coondog
post Mar 23 2021, 06:25 PM
James Patrick pitched this to me last month with a price around 6k. While it sounded nice I just didn’t want to mess with a system that’s not broke.
pete000
post Mar 23 2021, 07:19 PM
QUOTE(mepstein @ Mar 23 2021, 01:22 PM) *
(IMG:style_emoticons/default/agree.gif) Also
horizontally-opposed
post Mar 23 2021, 10:28 PM
Honestly, I'd love a way to run 3.2 Motronic—complete—on my 2.2.
Suspect the runners would be too big, and the chip would need "minor" revisions, and that there would be other issues—but one of the things I don't like about aftermarket setups is long-term parts/support. I'd hate to be in a 2020-2040 version of maintaining a 386 or 486 to run an old race car. No thanks…
But I'd also love to move on from carbs.
Maltese Falcon
post Mar 23 2021, 10:52 PM
This is a 3L SC engine with upgraded cams, Borla itb's and MoTec management. Also runs our headers + a custom fit gt3rs muffler. Sounds delish !
Mark Henry
post Mar 24 2021, 06:18 AM
that's what I do!
One thing about all these ITB systems is if your engine itself isn't up to snuff then it just expensive lipstick on a pig.
EFI itself doesn't add HP, the ITB open things up, but an engine is the sum of all its parts not just the bolt ons.
We'll see if there's much HP loss going from my 40mm webers with a Patrick twin plug dizzy to a single honda TB modified 964 intake with SDS EFI with crankfire. My engine is still fresh perfomance twin plug with healthy WEB 120/104 cams. My bet is there won't be a huge difference, especially for a street car. My prime objectives is a bit better gas milage,a bit less intake noise and less matanance than the carbs. Also I have another 914 project that will need the carbs and dizzy for.
If there's a big downgrade in HP I can always add ITB's, but I'd do another motorcycle TB mod like I did on my 2.6 nickies T4.
post Mar 24 2021, 06:24 AM
QUOTE(Mark Henry @ Mar 24 2021, 05:18 AM) *
Sounds like you're on the right track with reasonable goals. Jerry Woods used to say that you don't gain much peak hp with EFI vs carbs, but you gain a lot of performance. More torque, more of the time. More drivability. More consistent throttle response, which leads to more confidence, which leads to more speed.
Marty, that Borla setup looks delish. Didn't know they were in the ITB game, and have had Borla products in the past…and they were superb. Also like that it's a name that's been around a long time. (IMG:style_emoticons/default/idea.gif)
Steve
post Mar 24 2021, 08:27 AM
QUOTE(Coondog @ Mar 23 2021, 05:25 PM) *
6k installed? I doubt it.
ConeDodger
post Mar 24 2021, 09:36 AM
Apex killer!
ITB's can pretty much force you to tune by throttle position. All of that area opening up at the same time is confounding to MAP tuning.
Mark Henry
post Mar 24 2021, 09:42 AM
that's what I do!
QUOTE(Steve @ Mar 24 2021, 10:27 AM) *
I have to agree, $6K is the price for the entry level PMS ITB's alone, not including the EFI system.
To me the prices of the 911 ITB's are crazy money. I'd be buying a pair Triumph triples.
https://patrickmotorsports.com/collections/...njection-system
I'm building a 964 plenum based EFI system, I'm aiming to do it for under $1500....Canadian. (IMG:style_emoticons/default/biggrin.gif)
Below is my T4 motorcycle TB build, not counting build time I have no more than $200 into them.
http://www.914world.com/bbs2/index.php?sho...p;#entry1862152
- Lo-Fi Version Time is now: 2nd April 2026 - 01:02 PM
