Van's Porsche engine build, installing piston rings |
Geezer914 |
Apr 3 2021, 07:25 PM
Geezer914 Group: Members Posts: 1,433 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Watching Van's Porsche engine build on youtube installing the piston rings. He installed the ring with the dot for the top rings. I thought that is the second compression ring with the top rings un-marked??
rfinegan |
Apr 5 2021, 04:22 AM
Senior Member Group: Members Posts: 973 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region |
I just did in my Hasting rings on a set of KB pistons
First ring: un marked and Square- Can be installed in the first piston groove up or down does not matter Second ring. Has inside bevel- and DOT on one side- Installed on second piston groove with DOT facing UP Oil ring (3 pieces) Installed in Botton piston groove. Expander is installed with ends facing UP First. Followed by thin rings on top and bottom of space/oil control expander Hope this helps Watching Van's Porsche engine build on youtube installing the piston rings. He installed the ring with the dot for the top rings. I thought that is the second compression ring with the top rings un-marked?? |
Lo-Fi Version | Time is now: 1st June 2024 - 05:43 AM |
