| 930cabman |
Apr 14 2021, 05:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,572 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
We are converting a stock 2 liter 4 cyl from D jet to Webers. My gut is telling me a 40 IDF with 32mm venturis is the correct starting point. I am considering purchase of a complete set of 44 IDF's, but are unable to locate 32 mm venturis. Assuming 32MM venturis can be found are 44 IDF"s too large for a stock 2 liter?
thank you |
| nditiz1 |
Apr 14 2021, 05:11 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
40 IDFs are best, but 44s will work if you choke them down. I say 40s are best because they already come with 28 venturis. You may have a more difficult time dialing them in with 44s and bigger vents.
| barefoot |
Apr 14 2021, 05:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States
Question: is the diameter air the manifold interface different between the 2 ?
If the carb throat is larger than the manifold port size, a restriction is formed at that shoulder. Carb base diameter should match the manifold throat size. |
| johnhora |
Apr 14 2021, 05:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 902 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None
930cabman...
what's wrong with the stock D-Jet? have you tried to get it to work? If converting a stock engine to carbs use 40IDFs since no change to cam. |
| 930cabman |
Apr 14 2021, 06:06 PM
930cabman... what's wrong with the stock D-Jet? have you tried to get it to work? If converting a stock engine to carbs use 40IDFs since no change to cam. Several years ago I came upon a low mileage rust free Alfa spider (flood car), after rebuilding pretty much the entire car, the D jet stumped me with it's sensors, ECU and a million electrical connections. I found a set of Weber40 DCOE's and never looked back. If/when a FI system is reasonably new and working I would service it, but working from a basket case, no way. Tooo many variables |
| roblav1 |
Apr 14 2021, 06:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
At what what RPM is max HP? I'll take a swag at 5800. My Weber manual chart says 36mm venturi. A 36mm venturi is probably better with a 44IDF.
| 930cabman |
Apr 14 2021, 06:19 PM
This is a stock 2 liter 4 cylinder engine. my gut is telling me probably 32mm venturis
| roblav1 |
Apr 14 2021, 06:27 PM
My 5800 rpm swag was off. My 914 spec says max hp is at 4900 rpm. This'll decrease the main venturi size to about 32mm. So I would recommend 40IDF.
I forget how underpowered the T4 is! |
| type2man |
Apr 14 2021, 06:36 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
I would run 44 Webers. Personally I run 45 dells on a 2.0 with a cam and headers and have no issues. Dells are much better.
| 930cabman |
Apr 14 2021, 06:40 PM
My 5800 rpm swag was off. My 914 spec says max hp is at 4900 rpm. This'll decrease the main venturi size to about 32mm. So I would recommend 40IDF. I forget how underpowered the T4 is! Yes, with dished pistons/low compression it's near impossible yp make decent HP. If I live long enough and/or have some spare time I would like to try a twin turbo setup. I have not seen much on this board with this topic. Yes, my gut is telling me twin 40IDF's with 32mm venturis will work well with a stock 2 liter. 500cc/cylinder volume |
| IronHillRestorations |
Apr 14 2021, 07:11 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
You want 40's. With that engine the vacuum signal in 44's is going to give you problems. It will probably run very well with 40's and 28mm chokes
| johnhora |
Apr 14 2021, 07:20 PM
OK so you have:
Stock 2.0L type 4 with stock FI cam and distributor. And you have dual 40 IDF to install This is what we used on a customer 914 rebuild in 2019 2.0 L 009 Dist new one Web Cam... think it was an 86 Dual Weber 40 IDF Vents 28 AC 200 EM F11 Main 115 ID 55 Ran fine....they wanted just a driver. Maybe this will give you a start....GLW your project |
| johnhora |
Apr 14 2021, 07:29 PM
CB Performance's Bob Tomlinson's' book shows:
AirCooled VW engines with Dual 40IDFs 1835-2000cc 28mm venturi 145 M /220 AC /F11 E /55 Id 2000-2234cc 28mm venturi 150 M /225 AC /F11 E /55 Id |
| brant |
Apr 14 2021, 09:01 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
930cabman... what's wrong with the stock D-Jet? have you tried to get it to work? If converting a stock engine to carbs use 40IDFs since no change to cam. Several years ago I came upon a low mileage rust free Alfa spider (flood car), after rebuilding pretty much the entire car, the D jet stumped me with it's sensors, ECU and a million electrical connections. I found a set of Weber40 DCOE's and never looked back. If/when a FI system is reasonably new and working I would service it, but working from a basket case, no way. Tooo many variables What year Alfa? The spiders never came with Djet actually They were spica and then motronic DME Your car would be worth learning d jet They are a great and reliable system actually Almost like they were made for the car.... |
| 930cabman |
Apr 15 2021, 05:02 AM
930cabman... what's wrong with the stock D-Jet? have you tried to get it to work? If converting a stock engine to carbs use 40IDFs since no change to cam. Several years ago I came upon a low mileage rust free Alfa spider (flood car), after rebuilding pretty much the entire car, the D jet stumped me with it's sensors, ECU and a million electrical connections. I found a set of Weber40 DCOE's and never looked back. If/when a FI system is reasonably new and working I would service it, but working from a basket case, no way. Tooo many variables Once again, Thank you to all who responded for your information. My gut was telling me to go on the "small side" with regards to carb size. Anybody have a twin 40 IDF setup available? What year Alfa? The spiders never came with Djet actually They were spica and then motronic DME Your car would be worth learning d jet They are a great and reliable system actually Almost like they were made for the car.... 1985 Alfa spider, maybe it was L jet, but very similar. ECU, sensors, many many connections. When operating correctly the Bosch system is far superior to any carb system, but with 50 years old stuff, it's another story |
| Superhawk996 |
Apr 15 2021, 05:42 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,767 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
When operating correctly the Bosch system is far superior to any carb system, but with 50 years old stuff, it's another story Just for the record. That's what everyone said in the late 80's too. Not a carb hater by any stretch. Just think it's funny that the debate rages on 30 years later and I hear the same arguments out of both sides of the debate. (IMG:style_emoticons/default/laugh.gif) |
| 930cabman |
Apr 15 2021, 05:46 AM
For me, it comes down to simple.
Bolt on carbs, add fuel and go. 50 years old FI stuff = headaches |
| nditiz1 |
Apr 15 2021, 06:11 AM
Simplicity for me too. I worked with the black magic of the D-jet, but had more working knowledge of carbs. I had a harder time diagnosing an issue with the D-jet and started to take away things that could potentially cause issues, but were not needed i.e., Cold Start Valve, decel valve. Ultimately trying to get back to a simplistic system.
This does not mean that carbs are simple. They have their own set of rules you must follow and several have spent hours tuning them to the point where - well it gets me down the road. Suffering from poor mpg, bucking, overheating, just to name a few. Most of these stem from dirty carbs, incorrect jets, or linkage setup. If you start with a good working set and know your engine you can follow the methodical steps to get everything dialed in. What really helps is knowing how everything works together. I learned a big part of this a few years back when trying to tune a set on a new top end 2056. Learning that one could drive around with the main stacks removed was an eye opener. That is how you can set the idle jet and know exactly when the tip in starts for the main so as to not have a flat spot. That combine with an AFR can really help you dial them in perfectly. |
| VaccaRabite |
Apr 15 2021, 07:02 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
When I had my 2056 carbed I tried 44s and 40s.
The 44s had ALL the power in the top end. If I was racing, it would have been ideal. Car would hit readline and just KEEP GOING until I was floating valves. Not great for regular driving, but fun when I could open it up. 40s were a better mix, but did not have the same oomph that the 44s had. BUT I bet most of that was the defective gasket set I got that did not have all the jet holes punched and caused me to be fighting with the carbs so bad that I eventually went to EFI. That said, Microsquirt EFI has been the best. Zach |
| 930cabman |
Apr 15 2021, 07:27 AM
When I had my 2056 carbed I tried 44s and 40s. The 44s had ALL the power in the top end. If I was racing, it would have been ideal. Car would hit readline and just KEEP GOING until I was floating valves. Not great for regular driving, but fun when I could open it up. 40s were a better mix, but did not have the same oomph that the 44s had. BUT I bet most of that was the defective gasket set I got that did not have all the jet holes punched and caused me to be fighting with the carbs so bad that I eventually went to EFI. That said, Microsquirt EFI has been the best. Zach I hear guys talking about Microsquirt EFI, but I have no knowledge of this system, sounds complex (expensive) |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:17 PM |
