Recommendation for in-line fuel pressure gauge |
rjames |
May 3 2021, 09:48 AM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Anyone have a recommendation for a fuel pressure gauge that I can install in the engine compartment and leave there for a while? I don't need anything fancy. Just need something that will do the job and not leak and cause a fire hazard.
gereed75 |
May 3 2021, 10:00 AM
Senior Member Group: Members Posts: 1,260 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Anyone have a recommendation for a fuel pressure gauge that I can install in the engine compartment and leave there for a while? I don't need anything fancy. Just need something that will do the job and not leak and cause a fire hazard. I am using this one https://www.summitracing.com/search?SortBy=...ressure%20gauge It seems to be a higher quality built item as opposed to completely cheap Chinese ones. Hope I am not kidding myself because a failure could be ugly. |
GregAmy |
May 3 2021, 10:18 AM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Still using D-Jet? Get one with a 5/16" fuel line connection and clamp to the t-fitting on the stock fuel rail.
I have this for diagnosing various cars, and use an extended fuel hose when I want to monitor from inside the car. https://www.harborfreight.com/master-fuel-i...-kit-63727.html |
rjames |
May 3 2021, 10:38 AM
Still using D-Jet? Get one with a 5/16" fuel line connection and clamp to the t-fitting on the stock fuel rail. I have this for diagnosing various cars, and use an extended fuel hose when I want to monitor from inside the car. https://www.harborfreight.com/master-fuel-i...-kit-63727.html My fuel rail doesn't have the t fitting. on it. (If I'm understanding you correctly). And fuel line is 7mm I think. Isn't 5/16" too big? I don't want to any chances with the line leaking fuel. |
rjames |
May 3 2021, 10:40 AM
Anyone have a recommendation for a fuel pressure gauge that I can install in the engine compartment and leave there for a while? I don't need anything fancy. Just need something that will do the job and not leak and cause a fire hazard. I am using this one https://www.summitracing.com/search?SortBy=...ressure%20gauge It seems to be a higher quality built item as opposed to completely cheap Chinese ones. Hope I am not kidding myself because a failure could be ugly. Your link didn't go to a specific gauge, but linked to a page with over 2000 results. Can you post a link to the specific gauge? Thanks |
ndfrigi |
May 3 2021, 10:43 AM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
gereed75 |
May 3 2021, 10:46 AM
same as above
https://www.summitracing.com/parts/aei-15632 this is the low pressure one for carbs. There is a 0-100 one for FI |
930cabman |
May 3 2021, 01:31 PM
Advanced Member Group: Members Posts: 3,146 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
@ ndfrigi: where can I locate the barbed fitting with a 1/8" female pipe opening?
thank you |
rjames |
May 3 2021, 03:15 PM
Thanks everyone. Just put in an order to Summit.
ndfrigi |
May 3 2021, 03:24 PM
@ ndfrigi: where can I locate the barbed fitting with a 1/8" female pipe opening? thank you https://www.summitracing.com/parts/sum-g1710c |
Ansbacher |
May 3 2021, 03:49 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
Many fuel pressure gauges when mounted inside the engine compartment will give erroneously low readings after the compartment and the gauge heats up. You may be disappointed in an installation of this nature.
Ansbacher |
burton73 |
May 3 2021, 04:28 PM
burton73 Group: Members Posts: 3,551 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Where and what PMB used in number 41 my 6 USG brand for my PMO 46s
Bob B |
930cabman |
May 3 2021, 04:47 PM
Krieger |
May 3 2021, 05:40 PM
Advanced Member Group: Members Posts: 4,727 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Where and what PMB used in number 41 my 6 USG brand for my PMO 46s Bob B Is this a regulator/gauge combo unit? That is a restrictor/pressure gauge from PMO. It is designed to convert a fuel injected 911 with a high pressure fuel pump to carburetors. It is marginal for use. I had one and have been much happier with a Holley fuel pressure regulator and an Aeromotive low pressure gauge. |
roblav1 |
May 3 2021, 05:43 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I've used the PMO version in a couple cars.
930cabman |
May 3 2021, 05:51 PM
Does anyone make a gauge/pressure regulator combo reasonably priced? less than $50.
Lo-Fi Version | Time is now: 9th June 2024 - 03:08 PM |
