Ignition Switch, help |
cgrider25 |
May 18 2021, 12:38 PM
Newbie Group: Members Posts: 4 Joined: 23-November 19 From: Los Angeles Member No.: 23,668 Region Association: Southern California |
Hi All,
I just attempted to change the ignition switch on my 914. The previous one still worked, but I wanted to change the key. When I installed the new one, the car won't start. The lights will come on, but no power to radio or starter. I plugged the old one in, and the results were the same. I checked the fuses, but don't see any blown ones. Could I have tripped something, or is there something else I need to do? Thanks for the help. Chris |
914Sixer |
May 18 2021, 04:17 PM
914 Guru Group: Members Posts: 8,895 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You changed the mechanical lock part correct? Pull it out and check to see IF you broke the electrical portion. Center , right side of picture
Attached image(s) |
Lo-Fi Version | Time is now: 29th May 2024 - 05:12 AM |
