Changing from Tailshift to sideshift |
obscurity |
May 23 2021, 02:03 PM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
It has been years since I have been on 914world in a meaningful way or even worked on my '71 914. I am getting back into it and replacing the firewall. It occurs to me that if I ultimately want a side shift transmission I may want to go about this in a particular way. How should I go about making this change to side shift? I understand the linkage is a little different and that people often do this conversion without changing the fire wall but since I am here is there anything I should be doing?
I have been doing searches but so far have not found a definitive thread on the subject. I could be totally off base and maybe someone has figured out how to make the tail shift more usable and nobody makes the change anymore. |
bdstone914 |
May 23 2021, 03:49 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You dont need to change anything on the firewall. The tai lm shift has a differetn size hole for the shift rod and flange to mount the boot.
You would need a doner panel to add that. I dont have any. |
obscurity |
May 23 2021, 03:53 PM
Thanks! I should mention that I have the restoration hardware firewall which I assume has the later model setup. I do not have anything else for the sideshift including the shiftrod and transmission. I can keep the original setup if that is the better move.
Thanks |
bdstone914 |
May 23 2021, 04:24 PM
Here is a set of parts i sold to show all that is needed. I have many of them now.
http://www.914world.com/bbs2/index.php?sho...=351711&hl= Looks like RD makes both the early and late firewall. I would ask them if you can install the late wall in the early car. |
obscurity |
May 23 2021, 06:42 PM
Here is a set of parts i sold to show all that is needed. I have many of them now. http://www.914world.com/bbs2/index.php?sho...=351711&hl= Looks like RD makes both the early and late firewall. I would ask them if you can install the late wall in the early car. I'll have to check with them and see. When I bought it they were only offering the late model |
obscurity |
May 27 2021, 01:10 PM
Just an FYI, I spoke with Restoration Design and confirmed that the only difference between their early and late fire walls is the shift rod opening
rhodyguy |
May 27 2021, 01:36 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
They differ, early to late, in their shapes where the plastic cap/cover (early) and rubber boot (late) cover the F/R rod connection. Figure out your final path before you start welding the lower? Firewall. No point in the early version if you intend to go SS.
914Toy |
May 27 2021, 02:06 PM
Senior Member Group: Members Posts: 718 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
It has been years since I have been on 914world in a meaningful way or even worked on my '71 914. I am getting back into it and replacing the firewall. It occurs to me that if I ultimately want a side shift transmission I may want to go about this in a particular way. How should I go about making this change to side shift? I understand the linkage is a little different and that people often do this conversion without changing the fire wall but since I am here is there anything I should be doing? I have been doing searches but so far have not found a definitive thread on the subject. I could be totally off base and maybe someone has figured out how to make the tail shift more usable and nobody makes the change anymore. There is a piece of sheet metal in the early "end-shift" cars, roughly 4"x2" welded transversely to and inside the tunnel, about 6" to 7" from the rear of the gear shifter mounting hole. The gear shift rod in these "end-shift" cars, which is connected to the bottom of the shifter, passes through a 1.5" (approx.) round hole in this piece of sheet metal. This shift rod rotates in the early cars (with "end-shift" tranny's), where as the later "side-shift" mechanism has this rod rotating but also swinging from side to side, corresponding with the three gear shift gates. This hole needs to be increased by roughly at least 1/2" on each side (making it oval) to allow the rod free side to side travel. Unfortunately it requires cutting a small access hole (4"x2" approx.)in the top of the tunnel behind the location of this plate. Once you have access to the plate in the tunnel, you can see it and cut it accordingly to allow unrestricted movement of the shift rod. It is almost impossible to correctly adjust the shifter rod mechanism without this small modification. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:44 AM |
