914Rubber master cylinder replacement, connecting supply hoses to EZ install version |
fixer34 |
May 30 2021, 07:32 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
So finally getting around to installing the master cylinder I bought from 914Rubber over 4yrs ago. I got the EZ install kit with screw in adapters and 6in lengths of braided hose. Pulled the old MC out and have the steel supply lines still in place.
Should I just cut a couple inches off the existing lines and use a short length of the braided hose, or cut back further to use the entire hose length? |
76-914 |
May 31 2021, 12:24 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
6 of 1 and a 1/2 dozen of another; dealers choice. Doesn't matter. That rear connection is pretty close to the bulkhead and a PITA to access the hose clamp. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 4th June 2024 - 07:17 AM |
