Testing air flow meter |
partwerks |
Jun 17 2021, 05:47 AM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
ClayPerrine |
Jun 17 2021, 06:31 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The AFM consists of 3 internal parts:
1: Air temp sensor 2. Fuel Pump relay switch 3. Variable resistor The air temp sensor shares a common ground with the variable resistor on the 6 pin meter. On the 7 pin meter, the air temp sensor is isolated from the variable resistor. I don't remember the pinouts, but you should be able to find out by just popping the top off and look at the pins. Using a multimeter on the ohms setting, you should see a smooth sweep when opening the flap on the air flow meter. The switch will be open when the flap is closed, and you will get continuity on the switch when the flap is opened. The temp sensor is (IIRC) should have the same value readings as the temp sensor screwed in the top of the D-Jet intake. Hope that helps. Clay |
JeffBowlsby |
Jun 17 2021, 09:08 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
From the L-Jet manual
Attached image(s) |
cgnj |
Jun 18 2021, 07:52 AM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
PM me your email. I have a few documents to help you. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:35 AM |
