> Shift rod bushing bearing behind the knuckle disintegrated, Any luck replacing bushing
pete-stevers
post Jun 28 2021, 02:31 PM
Shinee Side Up Prep and Paint
I guess dealing with 50 yr old parts ... shit just happens. (IMG:style_emoticons/default/sad.gif)
The bushing gave up to ghost and disintegrated ,lucky for me I had a spare shift rod. I am just wondering what the solution is. Has anyone had luck re-bushing the shift rod
Replies(1 - 19)
Shivers
post Jun 28 2021, 02:39 PM
Maybe I'm dense today, can you post a picture of the bushing and area it is in.
GregAmy
post Jun 28 2021, 02:59 PM
https://www.pelicanparts.com/catalog/SuperC..._TSHIFT_pg2.htm
...and I'd recommend a new firewall bearing:
http://www.tangerineracing.com/transmission.htm
pete-stevers
post Jun 28 2021, 03:03 PM
It is part of the shift rod that is just behind the knuckle at the firewall... giving the knuckle the ability to rotate slightly up and down.
pete-stevers
post Jun 28 2021, 03:07 PM
QUOTE(GregAmy @ Jun 28 2021, 01:59 PM) *
I have installed the Tangerine bearing, It works great! (IMG:style_emoticons/default/piratenanner.gif)
The pelican kit does not include the bushing on the shift rod though.
Root_Werks
post Jun 28 2021, 03:10 PM
Village Idiot
I just stuck with the factory plastic bushing. Let is soak in very hot water for a while and it squishes in much easier.
Gotta pull the shift rod from the tranny side, pull the shifter out and slid the shifting rod out of the tunnel to make room to install the new bushing.
914e
post Jun 28 2021, 03:15 PM
These? Shift bushing
pete-stevers
post Jun 28 2021, 03:27 PM
Right here
914e
post Jun 28 2021, 03:43 PM
QUOTE(pete-stevers @ Jun 28 2021, 02:27 PM) *
Right here
The ones I linked should be the right ones. Getting the pin out can be difficult if it rusted.
BeatNavy
post Jun 28 2021, 04:14 PM
QUOTE(914e @ Jun 28 2021, 05:43 PM) *
Right here
Oh my, yes it can. PB blaster, drift, vise, heat, cheater bar, etc. It was a real PITA for me.
GregAmy
post Jun 28 2021, 04:29 PM
QUOTE(pete-stevers @ Jun 28 2021, 04:07 PM) *
You sure? Isn't that them in the bottom left of the photo?
Do the whole thing while you have it apart. Firewall, shift knuckle, bushings on the transaxle. Make it right.
If you really want to do it well, buy Tangerine's full shift rod kit plus firewall bushing. It's a bit of coin, but worth every penny. I did it on both mine and love it.
http://www.tangerineracing.com/shiftlinkage.htm
AZBanks
post Jun 28 2021, 04:49 PM
The bushings 914e posted are correct and they are part of the pelican kit.
Mikey914
post Jun 28 2021, 05:39 PM
The rubber man
Got them $6.98 a set
https://914rubber.com/shift-knuckle-bushing-1
Can be a little tricky to replace
http://www.914world.com/bbs2/index.php?sho...ost+4th+bushing
930cabman
post Jun 28 2021, 05:46 PM
QUOTE(Shivers @ Jun 28 2021, 02:39 PM) *
No problem, just as long it's today only, ......
Chris914n6
post Jun 28 2021, 06:14 PM
Jackstands are my life.
use caution with the cast aluminum piece, it will snap pretty easy (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/slap.gif)
sixnotfour
post Jun 28 2021, 09:35 PM
I jusy did a 911 ,,where someone just pushed new pushing in from the outside....Lasted a little while (IMG:style_emoticons/default/beer.gif) no flange on inside to hold in place. (IMG:style_emoticons/default/drunk.gif) I supose he made great time on the replacement..flatrate..
DRPHIL914
post Jun 29 2021, 07:31 AM
Dr. Phil
QUOTE(pete-stevers @ Jun 28 2021, 05:27 PM) *
Right here
i went thru this last year, biggest issue was getting that pin out it has splines on it that help keep it in place once pressed in , so you need a press. once that is pressed out,
clean it up and get the new brass bushings, much less play than the derlin ones, perfect fit, tight and smooth, also did the firewall bushing from RIX914parts. com,
or use stock Porsche or 914rubber, then get the brass one fro the console at thetransmission, and if you really want smooth shifting, get the whole Tangerine racing shift rod and rear console bushing. i think they use a different knuckle at the firewall similar to the steering u-joint.
so several options on this.
Good luck, -
ps. got the brass bushings from a seller on E-bay
maf914
post Jun 29 2021, 07:33 AM
Not a Guru!
One of my favorite bushing installation photos. I guess they couldn't get the pin out. (IMG:style_emoticons/default/idea.gif)
seanpaulmc
post Jun 29 2021, 07:37 AM
Original Customs - Mark - made a YouTube video on this years ago.
Check YT for 914 Shift Coupler Repair.
You can do it.
GregAmy
post Jun 29 2021, 07:50 AM
QUOTE(maf914 @ Jun 29 2021, 08:33 AM) *
Uhh, hmmm...I guess that'll work...?
I used a bench vice and sockets to press in and out.
- Lo-Fi Version Time is now: 2nd April 2026 - 09:21 AM
