jrmdir |
Member ![]() ![]() Group: Members Posts: 224 Joined: 13-May 21 From: Central Ohio Member No.: 25,544 Region Association: Upper MidWest ![]() ![]() |
Hi:
Mostly out of curiosity, I popped the top off of my oil filler canister and was surprised to find this black plastic plug down in the well. Obviously it fell out of the bottom of the cover where there is an access hole to remove the PCV valve. It snaps back in but due to aging is not tight enough to stay. Looks to me that the only purpose is to make sure the vented fumes go around the periphery of the filler neck on their way to the valve, instead of straight through. Any thoughts on whether or not it would be worth trying to replace or epoxy this? Thanks, Ron ![]() |
rfinegan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,083 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region ![]() ![]() |
Thanks, Found one those plugs on my tear down...now I know wear it went
Lo-Fi Version | Time is now: 1st July 2025 - 01:57 PM |
