ECM Help, 74’ L-jet 1.8 |
shane |
Aug 28 2021, 06:14 PM
Member Group: Members Posts: 355 Joined: 12-February 13 Member No.: 15,518 Region Association: None |
Removed the carburetor and installed the FI that the PO boxed up when he couldn’t get it to idle properly. So it’s running okay but has low idle when cold and some light popping on the deceleration when it warms up but not when cold. I’m going through the FI harness checking wires and using the harness diagrams on Bowlsby.net and noticed my ECM harness plug sockets doesn’t match the 74’ or the 75’ diagrams. So I removed the ECM and no numbers letters nothing on it. Is there anyway of finding out what ECM I have? The car mfg date is 3/74’. My thinking is possibly the harness wire locations may not match the ECM. Any help is appreciated
shane |
Aug 28 2021, 06:32 PM
It does have a 6 pole AFM and harness plug.
JeffBowlsby |
Aug 28 2021, 07:31 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Your harness is a late 1974 1.8L harness. That circuit #2 in the ECU connector is found on some of the later model year cars. It adds a circuit to the TPS if I recall and I believe I recall it being documented in factory literature. Don’t recall where without research.
shane |
Aug 28 2021, 11:54 PM
Your harness is a late 1974 1.8L harness. That circuit #2 in the ECU connector is found on some of the later model year cars. It adds a circuit to the TPS if I recall and I believe I recall it being documented in factory literature. Don’t recall where without research. Thanks! |
Lo-Fi Version | Time is now: 8th June 2024 - 02:59 PM |
