> 914World Classifieds Rules
> FS: Miscellaneous parts
partwerks
post Sep 2 2021, 07:50 PM
For sale: miscellaneous parts.
Paypal Friends and Family Option, or cash for local pickup.
Asking price + shipping.
All used parts, except for valve cover gaskets, and rear sway bar mounting brackets, and stiffener plates.
1. Steering shaft bellow/boot-$17.00
2. Lower rear trunk latch-$10.00-Sold
3. Upper rear trunk latch-Sold
A. One with spring & no bushing-$15.00-Sold
B. One without spring & no bushing-$10.00-Sold
4. Two lower front trunk latch
A. Missing the cable clip and screw-$20.00
B. Complete with cable clip and screw-$24.00
5. Upper front trunk latch--$14.00
6. Door striker plates w/o guide-$3.00 each
7. LH pedal board hold down clamp-Two available-$3.00 each. RH side, round one-$2.00 (not pictured)
8. Two front tunnel covers-$3.00 each
9. Two door stays.
A. Complete one-$6.00-Sold
B. Other one has the roller missing-$4.00
10. Speedometer cable- in working order-has some crows feet cracks around (small) end of boot that pushes up on
the firewall-$13.00
11. Two hood cable assemblies. Neither have the set screw that holds it in place under the dash.
1. One with plastic tube housing-$24.00
2. One without plastic tube housing-$20.00
12. DS engine lid grille section-$5.00-Sold
13. Fuel pump bracket-rubber isolators have some cracks in them.
$20.00-Sold
14. DS & PS door latches-$40.00 for the pair-Sold
15. Air box mounting bracket-$24.00-sold.
16. Rear sway bar mounting brackets & support plates, w/o bolts-$48.00
17. Relay board cover bolt-$20.00
18. Battery hold down clamp-$3.00-sold
19. Spare tire bolt-$5.00-Sold
20. Engine lid grille latch with bolts-$23.00
21. Clutch pulley bracket with nut-$8.00
22. Front targa latches. $62.00 for all four.
One pair is in decent condition. The other two are parts and repair to make one good one. One has a broken handle, and the other one, has a bent hook.
24. Pair of rear targa upper bumper receivers off of a 1974 top-One sold. One left-$23.00
25. Fuzzy strips. I think they are the inner ones? Seem like new-$4.00 each.
26. Two targa top centering wedges. One is missing one screw-$14.00 each. One with two screws is-Sold
27. Five lens retainer knobs-$5.00
28. Three sun visor mounts-$3.00 each-two sold, and one driver's side left.
29. Gas pedal adjustment stop bolt-$3.00
30. Two white targa top holders-hold the front edge of targe top in trunk-$4.00 each.
31. Roll bar latch surround (plastic) $3.00
32. Ski rack plastic plug-$2.00 Two available.
33. Trunk light-has a crack around one hole-$4.00
34.
35. Seat belt stop-$4.00
36. Triangle window cap-$2.00
37. Seat belt mount top cap-$3.00-Sold
38. Two rubber rear trunk targa top holder-Hold the rear of the targa top, in the trunk-$3.00 each-Sold
39. Brake fluid reservoir-has screen, but broken cap-$24.00
40. RH front side marker lens-prongs are broke-$13.00
41. Cigarette lighter housing-two in working order-$14.00 each. One sold, and one left.
42. Tripometer reset cables-one is missing the cap
One with knob-$15.00-Sold
One without the knob-$10.00
43.Emergency handbrake return spring-two available-$4.00 each-one is yellow plated.
44. Housing with rubber end. Was mounted in dash-$4.00
45. Valve cover gaskets-$7.00
46. Two black plastic pieces with two mounting holes, and a shark like fin sticking up? Were mounted under the dash-$4.00
47. Air deflectors-$10.00
48. Plastic elbows-one has over spray on it-$10.00
49. Rear targa latches-one has a piece of plastic broke off-otherwise in working order-$28.00-Sold.
https://grandisland.craigslist.org/pts/d/gr...7396979458.html
Replies(1 - 17)
Literati914
post Sep 2 2021, 08:51 PM
12, 19 & 26 for me pls.
partwerks
post Sep 2 2021, 09:04 PM
[quote name='Literati914' date='Sep 2 2021, 06:51 PM' post='2942588']
Made a note of it.
sjhenry1075
post Sep 4 2021, 09:09 AM
2 & 3 for me... I'm sending you a PM
Sea Rooster
post Sep 4 2021, 10:25 AM
I'll take: 42. Tripometer reset cables-one is missing the cap
partwerks
post Sep 13 2021, 10:19 PM
Bump.
AZBanks
post Sep 14 2021, 04:06 PM
I'll take one drivers side and one passenger side for #28 and #18
partwerks
post Sep 14 2021, 04:32 PM
QUOTE(AZBanks @ Sep 14 2021, 02:06 PM) *
PM sent.
MM1
post Sep 15 2021, 10:58 AM
914 obsession continues
9 and 9A for me please - sending PM now.
CSoso
post Sep 18 2021, 08:27 PM
Over-analyzing one mistake at a time...
PM sent on #49.
partwerks
post Sep 18 2021, 09:39 PM
QUOTE(CSoso @ Sep 18 2021, 06:27 PM) *
PM sent on #49.
PM sent.
partwerks
post Sep 22 2021, 07:31 PM
Bump.
partwerks
post Oct 20 2021, 07:33 PM
Bump.
partwerks
post Nov 6 2021, 09:45 PM
Bump.
partwerks
post Nov 14 2021, 04:44 PM
Bump.
partwerks
post Nov 27 2021, 10:48 PM
Bump.
partwerks
post Dec 13 2021, 07:37 PM
Bump.
partwerks
post Dec 19 2021, 05:08 PM
Bump.
- Lo-Fi Version Time is now: 7th July 2026 - 09:54 PM
